Head and cam progress, this swap has been more than I bargained for
I must say that was a very interesting job you gave me Jon... After the look in Daves face making that last twist I knew it.
I have pulled many broken bolts out before but that by far was my hardest... My biggest fear was drilling in to the block. But 3 hours and some custom fabing of tools it all worked out. I am just glad we got it out.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
1 Post
Originally Posted by slt200mph
Congrats on getting it out!!!..I know that must have stressed you to the max...good luck with your install !!
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
Then Mark
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
1 Post
Well I got the new ARP bolts in yesterday. I got off this morning and re-installed one head and got the other put on and all is well so far. The rockers are on, valve covers, intake, waterpump, power steering pump...I hope to be done soon. I just came in to take a short water break.
reclean the bolt holes. after you are certain that they are clean, lube the bolt with engine oil, not alot, just one edge of the bolt. that should help out. Grind an old bolt flat on 2 sides, push a paper towel in to make sure everything is out of there.
#33
Originally Posted by ExceSSive
Well the thanks to God and Wide Open Throttle performance my beast is alive and breathing again.
So how's it running? Are you happy with it? How's it sound....much of a lope or no? I have the same cam as you do....but the 112 version, and it makes the car shake pretty good
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Manny
