heads/cam question
Old Aug 22, 2005 | 02:14 PM
01SS346's Avatar
Default heads/cam question
I have a x2 cam and I have a option to buy these:
TEA(total Engine Airflow) Stage 1.5 5.3L heads
CNC Port LS1 5.3 Stage 1.5
3.900” Combustion Chamber
Competition Multi-Angle Valve Job
Blend Valve Job
Mill Heads to Customer Specs
Flow Intake and Exhaust Ports
Heads Cleaned, Set Spring Heights, Assemble, Seat Pressure, Installed Height, and Coil Bind
Ferrea 2.020 Intake Valve
Stock LS1 1.550 Exhaust Valve (REV 1.57” Exhaust Valves are also available)
Standard TEA .650" Lift Dual Spring” (Comp 1.250” 921 and Comp 1.440” 978 are also available)
TEA Titanium Retainer
TEA Locators
GM Locks
GM Intake and Exhaust Valve Seals
my question is
1) will I have to flycut pistons or no (I really dont want to)
2) will the valves be ok the lift on the cam is a 608 lift so I dunno.
Thanks for the assist
Old Aug 22, 2005 | 02:20 PM
bowtieman81's Avatar
How much were the heads milled? And what gaskets are you thinking about?
Old Aug 22, 2005 | 02:24 PM
99ssleeper's Avatar
They should be ok. A friend of mine has the MS3 cam (.600+) lift and his heads are milled quite a bit and he has no problems. I dont think you'll have a prob but I would clay the valves quick just to make sure...only takes about 20 mins.
I like my TEAs
Old Aug 22, 2005 | 02:27 PM
01SS346's Avatar
Im not sure what gaskets I would use. I will clay it I just dont want to spend the $$ if its not going to work haha im nervous
Old Aug 22, 2005 | 03:04 PM
99ssleeper's Avatar
Use GM gaskets. Mine were $54 shipped 2nd day from sdpc2000.com
Chevrolet has a 10 day wait and they are $45 each, GMPartsDirect is $213 shipped...lol.
SDPC is great to deal with!
Old Aug 22, 2005 | 04:11 PM
01SS346's Avatar
Ttt
Old Aug 22, 2005 | 11:34 PM
lsx24's Avatar
A contributing factor would be the similarities or extension of 5.7l and 5.3l heads, correct? Because I'm fairly certain 5.7l heads should clear very nicely.
Old Aug 23, 2005 | 12:06 AM
WS6freak's Avatar
No! .608 is too much for those heads. You won't have enough p/v clearance there. I have those heads with the F13 cam (.585 lift) and the clearance was only .0050 with compressed gasket. The guy who installed the whole shabang had the valves re-worked so he could see .0075 clearance. This is the right way to do it so you don't lose compression (11:1) on those heads - using a thicker gasket is the easy way but you'll lose compression and compression is power.
If you rev up the engine and have a slight float, you're DONE. Bent valves, bent pushrods, who knows what. And get new lifters! Not worth the risk using the stockers.
Old Aug 23, 2005 | 12:30 AM
lsx24's Avatar
Seventy thousands is accurate for that combination I guess.
