TR230 is in!
Old Aug 29, 2005 | 10:33 AM
LS1powerhouse02's Avatar
Originally Posted by FstBlkz28
I'm live at the Exchange on Luther St. Lemme know when your putting it in, and if you want I can give ya a hand, or at the least give ya some tips on the install. When do you think you'll be putting it in?
I live in a house on Milner street right behind that East Gate strip off of Texas. I'm not sure yet if i am gonna put it in here or go back to columbus (my hometown) to an auto shop i work at. Do u think i could do it here or is it really gonna be a hard job? I am hopin to get it put in sometime in the next few weeks.
Old Aug 29, 2005 | 05:48 PM
FstBlkz28's Avatar
Originally Posted by Hennytime
wow, so let me get this straight, you stuck in the cam, and untuned it made 394hp on stock heads...
Untuned (my baseline pull) was 370 to the wheels. Sean at fastech, then picked up ~16hp through tuning it. Then I went to another shop in the area and had it dyno'd b/c I had dyno'd my car at the shop back before the cam went in and I wanted to get a real comparison on what I had picked up. That is where I dyno'd 395/377.
Old Aug 29, 2005 | 05:56 PM
txhorns281's Avatar
Gotta love that cam...
Old Aug 29, 2005 | 05:59 PM
FstBlkz28's Avatar
All you really need is a set of rhino ramps to roll the front of the car up on. Bascially, if you've got a 10mm and a 15mm wrench/socket your all set to do the cam swap. I'll probably be going home w/in the next week or two and could pick up my valve spring compressor while I'm put there as well. All in all, its really not that hard of a job, just alil time consuming. My install was going along smoothly until the lifter fell, and I probably would have had the car back up and running w/in the same day I started the install.
Old Aug 29, 2005 | 09:10 PM
Just curious now... what kind of hp do you think i should be lookin at with this cam 230 duration 591 lift 110lsa and +4 degrees timing i have a whisper lid and flowmaster exhaust. No headers yet... although they will be ordered soon after. And just wonderin if i could get some pointers on gettin it tuned. Im on a pretty tight budget though. We need to meet up sometime so i can check out your car
o yah and we are supposed to have a party this thursday if your interested
Old Aug 29, 2005 | 09:34 PM
badpewter-z's Avatar
LS1TECH Sponsor
had teh tr230 for almost a yr before i pulled it i loved that cam and still is making power for the car i sold it to. i miss the sound of that cam
Old Aug 29, 2005 | 10:13 PM
FstBlkz28's Avatar
Once you had the headers, you'd probably be looking at a step above the levels I'm making. The reason I chose the reverse split is b/c my exhaust setup is very free flowing: LT's, 3" duals w/ an X pipe dumped at the axle. I also picked it b/c of the gains I was seeing ppl get and the relatively small lift #'s that it had compared to the other cams that were making power. My car is my daily driver and only car ... so I didn't want it to be going thru springs every 15k.
What time do you get done w/ classes each day? I'll PM you my # and we can meet up sometime this week and talk cars
Old Aug 29, 2005 | 11:59 PM
erodrig2's Avatar
Thats the cam im running. Just about the same dyno #'s. Its a good cam it pulls nasty on 3 & 4. Now im shopping around for a bigger cam and some heads. I just want more HP.
Old Aug 30, 2005 | 11:06 AM
1CAMWNDR's Avatar
Try and post another sound clip. I'd love to hear that through dual exhaust.
Old Sep 3, 2005 | 09:11 PM
gillbot's Avatar
What's your idle speed set at?
Here's mine with the TR230:
http://video.ls1tech.com/Player.aspx...F-A6BBE6B04249
Old Sep 6, 2005 | 09:44 PM
FstBlkz28's Avatar
gillbot - for the clip in my first post when it was untuned it my idle was set at 800.
1CAMWNDR - i'll see if i can't get another clip of it, and upload it for ya
Now that its tuned it idles at 900 ... but i'm going to go back when I get back home and have the idle lowered back down to 800 if i can.
Old Sep 7, 2005 | 05:22 AM
  #32
gillbot's Avatar
I used to have mine idle at 750-800 but I kept setting Randon Misfire and Low MAP codes, I bumped it up to 850 and I haven't seen one since.
EDIT> My idle is set at 850 and 900 with AC on.
Old Sep 7, 2005 | 11:47 AM
  #33
FstBlkz28's Avatar
Yea, I think that when Sean tuned my car he just tuned it for a flat 900 idle ... I'm not 100% sure of this, but when I scan the car w/ EFILive ... the desired idle stays at 900 whether the A/C is on or off.
Old Sep 7, 2005 | 02:44 PM
  #34
1CAMWNDR's Avatar
...........1CAMWNDR - i'll see if i can't get another clip of it, and upload it for ya..................
Let me know if you get one up .
Old Sep 7, 2005 | 05:00 PM
  #35
gillbot's Avatar
Yeah, probably set at a flat idle then. Still sounds great though!
Old Sep 22, 2005 | 09:09 PM
  #36
GTA91's Avatar
I've got this cam in mine as well. Getting ready to fire it up for the first time here in a few minutes....
'91 GTA Trans Am with a '98 LS1/T56/moser 9" with 4.11s. Ported heads, comp 918s, titanium retainers, ARP rod bolts, ported TR LS6 oil pump, double roller timing chain, TR 7.40's, LS6 intake, ported MAF & TB, ASP pulley, custom SW LTs, and my custom 4" CAI.... we'll see how it does... can't wait. I'll post some vids after its running!
later- Jeremy
