*****New FFHP Spring Tool*****
Old Aug 30, 2005 | 01:28 PM
xfactor_pitbulls's Avatar
Originally Posted by Dixit
True, but it balances that would since the tool is using both studs. So each spring is still using one stud to hold the spring pressure.
Dixit
What? It uses one threaded bolt, into one set of threads and compresses two springs.
Brandon
Old Aug 30, 2005 | 03:12 PM
Nittany_marine's Avatar
looks like a good tool to have if you are one of us who needs to sawp then out more than once. I wish I had that on my first cam swap.
Old Aug 31, 2005 | 04:56 AM
Demon SS's Avatar
Brandon
no it uses two threaded bolts into two threaded rocker arm stands to compress two springs
the base plate covers two rocker arm stands and is bolted to both of them, the single stud is centered between the two springs and the top plated is placed over that and creates the compressing force on the springs.
