Plugs for 11.2:1 compression
Old Aug 31, 2005 | 08:54 AM
xfactor_pitbulls's Avatar
Default Plugs for 11.2:1 compression
I have been having a problem with my car pulling timing from 28* back to 24 and 22. I wonder if the TR55 plugs arent a bit hot for the compression and timing. I am thinking about going to the TR6. What do you guys think?
Brandon
Old Aug 31, 2005 | 09:23 AM
LOnSLO's Avatar
TR55 all day. You may have false knock, or maybe a bad knock sensor. Or you could be running a little lean, or...............
Old Aug 31, 2005 | 09:31 AM
roadrash9r's Avatar
try closing the gap up some. Maybe .045 or .040
Old Aug 31, 2005 | 09:35 AM
Patrick G's Avatar
LS1 Tech Administrator
TR 6s are not a bad idea with a little bit bigger gap (stock is around .038"). I'm running stock gapped TR 6s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 31, 2005 | 10:05 AM
John02SS's Avatar
In my old motor I ran 11.1 and I used TR6 gapped at .045. In the new setup I'll be running 11.5 and will run the same TR6 gapped at .045 for NA applications. They have worked flawlessly for me on 93 octane and 31 degrees of timing.
John
Old Aug 31, 2005 | 10:15 AM
I'll check my gap when I go home tonight. Thanks for the input.
Brandon
Old Aug 31, 2005 | 11:27 AM
SideStep's Avatar
Is there a downside to running a cooler plug??? Less power???
Old Aug 31, 2005 | 02:12 PM
racecar's Avatar
Colder plugs can foul at lower rpm. I have 11.5:1 compression, have to mix race fuel with pump gas to keep it from knocking at WOT.
Old Aug 31, 2005 | 02:15 PM
777's Avatar
777
I'd run the TR-6's @ .040-.045
