how big of a cam an stock motor
Old Sep 5, 2005 | 04:27 AM
2000nbmSS's Avatar
Default how big of a cam on a stock motor
how big of a cam can i run before having to fly cut pistons.
Old Sep 5, 2005 | 06:46 AM
lsx24's Avatar
go ahead and remove the tr224 .. andtalso the tr230
Old Sep 5, 2005 | 06:53 AM
2000nbmSS's Avatar
what is the most lift what i am asking
Old Sep 5, 2005 | 06:58 AM
PREDATOR-Z's Avatar
PTV is more related to duration and lsa than lift, although eventually lift will play a role.
But so far, T-Rex is about as big as you can stuff the stock motor
Old Sep 5, 2005 | 07:00 AM
FloridaZ's Avatar
T-REX
2000nbmSS's Avatar
thats what i have been wondering i would like to make good power from cam only. what are the specs on the t-rex?
Old Sep 5, 2005 | 07:03 AM
1FST99Z's Avatar
what are you trying to accomplish with the motor. You might want to look at what the best combination of cam/boltons that you have. to give you the best numbers. I mean with my setup most people are getting in the 420's at the wheels with all the bolt on's. but once you throw a set of good heads on the car you may only gain 20 or so at the wheels. where as if you go with somthing like a f13 you might not gain as much now with cam only, but that cam loves a set of p/p heads. Gomer on here has a car that made 487 with all the bolt on's and the smaller F13 with some well worked 5.3's. o well just my .02. so it is mainly all up to what you want.
Old Sep 5, 2005 | 07:05 AM
2000nbmSS's Avatar
i want to do h/c but right now start with a good cam and boltons
Old Sep 5, 2005 | 07:08 AM
FloridaZ's Avatar
Thunder Racing Custom Camshaft - T-ReX v.2 - 242/248 - .608/.612 - 110 lsa 3500-6700 RPM Power Band. Violent mid-range & high RPM power. Requires computer tuning, 4000+ converter on autos, 4.10's or greater on manual trans cars. Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended. Due to the extreme nature of this camshaft, piston to valve clearance must be verified when using modified cylinder heads.
i plan on running the trex for now. Probably a little too much cam for most as a daily driver. Many do it. Mines a weekend warrior, so i want it to make some noise. Later when i get heads, i'll get a cam to match. The qtp quick cam cover would be sweet to have too.
Old Sep 5, 2005 | 07:15 AM
2000nbmSS's Avatar
thats is a nasty cam. i am still stuck in old school gm i had a 78 el camino with 355 s/b dart heads 2.02,1.60 with a 305h at0.050 0.555 0.555
Old Sep 5, 2005 | 07:17 AM
PREDATOR-Z's Avatar
IMO, I'm not an advocate of those Huuuge cams for street applications on a stock bottom motor.
You want a big gun, you got to be able to handle the kickback.
There are many more streetable cams that will make as much power and more with the proper matching parts.
Build it right or back off, that has always been my moto.
Old Sep 5, 2005 | 07:18 AM
FloridaZ's Avatar
Thumbs up
check this..
http://ls1sounds.com/camshafts.htm
scroll down about half way to the 99 T/A with dynatechs, borla, and t-rex
Old Sep 5, 2005 | 07:22 AM
2000nbmSS's Avatar
that was my toy but now and gone i dont mind street maners that much but i am looking for good advice .new to the hole GENlll motor thing but not to racing or mods
Old Sep 5, 2005 | 07:32 AM
lsx24's Avatar
There are a variety of cams that would be ideal without flycutting
f11 for instance .
