Comp Cam beehive springs ???
thanksfor the info guys.
fuerzaws6
If you have he heads and just want to replace springs then just get PP "Gold" replacements. (That is if they need replacing)
these are new heads. what I'm looking at is to avoid floating valves or crash. I want to be able to set rev limit to 6600 and shift around 6300 rpm's . Hot Rod mag did a test on the beehive springs and found that these springs can rev about 1000 rpm more then the dual springs before any of these symptons accur. just trying to get alot of info on the beehive springs.
thanks again guys
fuerzaws6
thanks again guys
fuerzaws6
fuerzaws6
Comps are $199 and Crane a little more $275 (better than Comp though)
Most issues are with stockers collapsing.
