Should I replace my stock oil pump?
Old Sep 7, 2005 | 08:43 PM
SSDoubleK's Avatar
Question Should I replace my stock oil pump?
Okay car is still apart, was wonderning since I have read a couple of posts on people with 98's blowing up there motors due to oil pump failure. Was hoping I was a lucky one and that won't happen to me. Car has 32,000. Thanx for input.
Old Sep 7, 2005 | 08:50 PM
bad0211secws6's Avatar
definitely put a new gm pump in i would also put in a new gm timing chain.the new timing chains part numbers have all been updated to ls2 design!
Old Sep 7, 2005 | 08:58 PM
TA TECH's Avatar
Yeah the new LS2 chain and new gm pump are what I put on most all my projects!
Old Sep 7, 2005 | 09:09 PM
SSDoubleK's Avatar
Okay, I take the new LS2 chain will fit just like my 98chain, and when I go to the dealer do I ask for a 98Chain and pump or for a LS2 chain and pump replacement? Looks like I may never get this car back together. The pump change looks a little tricky. Thanx for the input.
Old Sep 7, 2005 | 09:11 PM
the updated parts replaced all the old part numbers
Old Sep 7, 2005 | 09:16 PM
TA TECH's Avatar
Yeah its the same chain they use on the 6.0 trucks just ask for a 05 gto 6.0 timing chain and a 03 vette oil pump thats what I do so the ywant screw it up!And get a new oil pump oring! Just slide the pump back on enough to get the teeth lined up after the chain has been put on and after its line up teeth wise pull it back off almost all the way till it has some up and down motion and pull the oil pick up tube straight out and slide them together out some light grease on the oring in the pump so it slides in easier and there ya have it! Best way not pench a o-ring!
Old Sep 7, 2005 | 11:18 PM
SSDoubleK's Avatar
Okay, thanx for the info. gonna hope I can get the parts by Friday.
Old Sep 8, 2005 | 02:21 AM
LS1FIRE's Avatar
I bought a ported oil pump from TSP with a new seal and went with the ls2 chain. I had almost 60,000 miles on the car and the stock oil pump o ring seal had a small cut in it.
