Just Talked To Dart.....
Old Oct 7, 2005 | 12:21 PM
  #241
CHRISPY's Avatar
Originally Posted by SStrokerAce
I was told they will start to ship around the begining of November.
Thanks
Any plans for a 4.0-4.125 bore version?
Old Oct 8, 2005 | 03:07 PM
  #242
SStrokerAce's Avatar
Porting and Valve size are really the only things that change in relation to the bore size. Both castings use the same seats and you should be able to put enough valve in there to work with either the 4.0" or 4.125" bore.
Bret
Old Oct 8, 2005 | 08:32 PM
  #243
MUSTANGEATER's Avatar
Bret
Matt Damon
Old Oct 11, 2005 | 01:34 PM
  #244
Dart331Stroker's Avatar
Default Bore size
I agree with what Bret said, the bigger bores will work with the heads, typically the larger bore engines like the larger runners and bigger bores.
Titanium retainers: We buy these right from Trick, which makes all the titanium bellhousings for Top Fuel cars, they also supply all of the companies, like Comp, Crane and several others with their retainers. They to our knowledge are the only US maker of Titanium retainers. Cost is material, and it will get worse I am sure, but nonetheless, beehive springs, bead lock keapers and the crazy factory seal with shim and locator built in are all more expensive than typical Chevy parts. This trend wont change until the demand is so high that parts are more mass produced than they normally are. There are 90 Million conventional chevy motors out there that GM has made, that doesnt count Vortec, LS, and LT series engines. SO you can imagine what the products ratio is for parts for conventional Chevy engines to LS series engines.
The initial design of the new valve weighed in at 97grams, and we are not done with it yet, so it should be pretty close to the stock valve.
Will have more information as its available.
Old Oct 11, 2005 | 05:08 PM
  #245
Skele4door's Avatar
Is it just me or is the casting a bit thin on the intake runner shown in the last pic? I can't make out if it's a water jacket or an intake bolt hole, but it looks like something is going to encroach on the intake tract. Either way I'm sure Dart will take care of it for their final castings, but I'm just a bit curious. Thanks for stepping up and making an affordable aftermarket casting for us GenIII guys.
These are big so I will warn ya in advance. It would be best to have the computer set to size these to your screen!
http://www.mofbody.com/Floyd/DSCN1150.JPG
http://www.mofbody.com/Floyd/DSCN1151.JPG
http://www.mofbody.com/Floyd/DSCN1152.JPG
http://www.mofbody.com/Floyd/DSCN1153.JPG
http://www.mofbody.com/Floyd/DSCN1154.JPG
http://www.mofbody.com/Floyd/DSCN1155.JPG
BTW Dart is switching to a 8mm valve setup now so you guys dont have to worry about parts interchangeability. Thats even cooler! From what I have heard the head has been revised two times already by a head department that does Pro Stock work all day. I'm excited to see what they do on a motor!
Bret
Old Oct 12, 2005 | 08:44 AM
  #246
Malihoochie's Avatar
Skele4door - I don't understand where you are referring to. The castings are definitly not thin, I think you may be reffering to the pushrod holes? BTW a RX7 with a LS1 =
Old Oct 12, 2005 | 10:37 AM
  #247
1CAMWNDR's Avatar
That hole appears to be threaded so I think it is the rocker arm bolt hole. No big deal .
Old Oct 12, 2005 | 11:00 AM
  #248
BIRDONNOS's Avatar
hopefully these heads will be ready before christmas would be a nice present
 Michael S. Palmer
Old Oct 12, 2005 | 11:08 AM
  #249
matstang's Avatar
YEAHHHHH!!!!!!
Old Oct 13, 2005 | 08:50 AM
  #250
We're striving for ship dates of late October for bare heads, but after our latest revisions the reality is looking like assemblies will probably be shipping around the middle of November (hopefully).
Old Oct 21, 2005 | 11:31 AM
  #251
The guides are being produced for these heads right now. The assemblies are still on schedule for November.
Old Oct 28, 2005 | 06:15 PM
  #252
stevieturbo's Avatar
I think I might invest in a set of these next year !!!!!
Old Oct 30, 2005 | 06:07 PM
  #253
INVISIBLEZ's Avatar
I'm sold, damn it's about time the working man can afford a good set of heads....
Old Oct 31, 2005 | 10:33 AM
  #254
98A4LS1's Avatar
Ditto my thoughts!
Old Nov 9, 2005 | 04:58 PM
  #255
Latest news is that all current orders should ship by the end of November!
Old Nov 10, 2005 | 02:38 PM
  #256
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Can anyone recommend which Dart head, cam and CR to use for this application?
01 Vette 6 speed LS1 Stock bore and stroke, Forged rods and pistons. Magnacharger at 8 to 10 PSI w. alky. Kooks 1 3/4" LT's w/ hiflow cats, etc.
Motor is coming out this weekend. So pistons and rods haven't been ordered.
Thinking about JE's and Scat rods.
Old hp was 435 rwhp with just Maggie and alky @ 7 PSI (no headers)
A slightly rough idle is desired as long as coupled with more power to around 7k.
BTW What power can a setup like this make? (Looking for well over 500 rwhp and oodles of torque)
Old Nov 10, 2005 | 02:51 PM
  #257
xfactor_pitbulls's Avatar
Bret
Agreed, even with an LS1 casting when you upgrade the intake seat for a larger than 2.03 valve, it will take you up to about 2.12
Brandon
Old Nov 10, 2005 | 09:09 PM
  #258
Wet 1's Avatar
I'm not sure why you're changing the pistons and rods given that you're not planning on leaning on it very hard. Your stock short block should handle 10 psi without a problem. If you must change the pistons Diamond and Malhe make nice FI pistons for the money. Scat rods are nice as well.
Than setup you listed should make plenty of TQ, but you're not going much over 500 rwhp with that Maggie... another reason I say to leave the stock short block.
Use the 225 Darts with this combo, you want the larger heads with your combo and goals.
Old Nov 10, 2005 | 10:48 PM
  #259
dabe's Avatar
any one have flow numbers as casted??
Old Nov 11, 2005 | 01:28 AM
  #260
rjw's Avatar
rjw
I have 3 cylinders with very low compression and heavy smoke pumping out of the oil cap.
The flow numbers on the 225 head aren't that much higher under .550 lift. Or are they?
