Just Talked To Dart.....
Old Dec 14, 2005 | 05:12 AM
  #301
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
A couple of days ago, SDPC had 205's in stock and 225's on the way
Old Dec 14, 2005 | 05:54 AM
  #302
vettenuts's Avatar
Originally Posted by Dart331Stroker
The current PSI spring with its spring diameter installed at 1.800 with a coil bind of 1.100 giving a .060 clearance average would allow .640 lift in reality, but wouldwe run that spring on that much lift, no it wont last and wont like the higher rpm. The newer spring has better material and will be able to handle the higher lifts.
What newer spring? Are the PSI's being replaced with another spring and if so, when will this occur and how will we know which we are getting?
Is the new spring a beehive design as well?
Old Dec 14, 2005 | 09:39 AM
  #303
Galen's Avatar
I already ordered my set from Summit with the expected ship date of Christmas Eve. I would like to know what springs I will be getting with my heads also. I do know they will be used with a G5x3 cam on a 114 cut, so my lift will be .600/.610.
Thanks!
Galen
Old Dec 14, 2005 | 09:55 AM
  #304
oldschoolmuscle's Avatar
I to am curious about this, since i plan on running a tsp 233/239 .603/.605
i also checked summit the 205's say they are available to shipout today.
and the 225 1/23/06
Old Dec 14, 2005 | 09:56 AM
  #305
rjw's Avatar
rjw
The set of 225's I received had beehives. I posted some dimensions here
https://ls1tech.com/forums/generation-iii-internal-engine/420440-just-got-set-set-dart-225-s.html
Old Dec 14, 2005 | 11:33 AM
  #306
Malihoochie's Avatar
All assemblies will have the PSI #1511 springs
Old Dec 14, 2005 | 12:36 PM
  #307
Galen's Avatar
Ok, now the confusion sets in. Not that I think it will matter for my situation, but if there is a spring change, I would really like to know when the change is taking effect.
Galen
Old Dec 14, 2005 | 01:17 PM
  #308
It is not a current production change. All the current assemblies have the PSI 1511's.
I'm quite sure we will let this board know if a change occurs.
BTW - The spring under consideration is also a beehive.
Old Dec 15, 2005 | 05:24 PM
  #309
SStrokerAce's Avatar
I'm just waiting on some ARP's to come in and we can start putting this all on a motor. Then the fun part is battling the snow and getting things on the dyno....
Bret
Old Dec 15, 2005 | 06:41 PM
  #310
Ed Curtis's Avatar
Talking
Bret
Lightweight...
Just put the studded snow tires on will ya!
Ed
Old Dec 16, 2005 | 09:06 AM
  #311
Yea - c'mon Bret. Get a move on ! Your PRI recoup time has elapsed.
Old Jan 5, 2006 | 05:03 PM
  #312
Bill Bowling's Avatar
and the 225 1/23/06
Now Summit says Feb for the 205's.
Bill
Old Jan 5, 2006 | 05:06 PM
  #313
vettenuts's Avatar
Try Jason at TSP, I think he has them in stock.
Old Jan 6, 2006 | 08:47 AM
  #314
Summit is pessimistic. They'll have 'em sooner than that.
Old Jan 6, 2006 | 09:59 AM
  #315
Galen's Avatar
When I ordered my 225s in early Dec, the expected ship date was 24 Dec...did they mean 2006?
Old Jan 6, 2006 | 10:46 AM
  #316
They often tell people that they are waiting on a distant shipment ... usually 4-6 weeks away ... nope! We ship to them at least every two weeks if not more often. Currently there are 80 open orders for 205cc heads. Where you are in "line" depends on when the order was placed. I think that 30 more 205's were delivered today, so after being valve jobbed, blended, etc. they'll go out to the customers. Also 30 225's were delivered, but the backorder list on those is currently around 110 open orders. I know it feels like but hang in there, these heads are a hot item. You guys should be glad that guys like Jason at TSP had the foresight to order early . Many vendors are reactive to the market rather than proactive to it's demands.
Old Jan 6, 2006 | 11:07 AM
  #317
vettenuts's Avatar
Jason is also a supporting vendor, Summit is not
I got mine from Jason
Old Jan 6, 2006 | 11:13 AM
  #318
Now hurry up & put yours on - so these other guys can drool over your #s/times.
Old Jan 7, 2006 | 09:25 AM
  #319
WizeAss's Avatar
bump.... (search doesnt work )
Old Jan 7, 2006 | 09:58 AM
  #320
CashMoney's Avatar
Yup I'm looking for heads and I'm wondering how these are?
