Thinking of replacing cam, need thoughts...
Old Sep 10, 2005 | 09:30 AM
Byter's Avatar
Default Thinking of replacing cam, need thoughts...
Check out my sig. I'm thinking of replacing the XER cam for a cam with less agressive lobes. The setup that looks good to me is the Vinci "The Beast" cam (really a Crane cam):
DUR @ .004" 290*/ 294*
DUR @ .050" 228*/ 232*
LIFT .551 / .551
OVERLAP 68*
LSA 112*
With a set of the Crane Gold-Race rockers at a 1.8 ratio.
My questions are:
1) Does anyone have this cam installed? How about the .600 lift version?
2) I don't race, but don't need "daily driver" driveability. Will this cam drive ok?
3) Do you think my 3.42 gears are too small for a cam of this size and RPM range?
Any other comments are welcome. Thanks!
Old Sep 10, 2005 | 09:39 AM
PREDATOR-Z's Avatar
So, let me get this straight. You want less agressive lobes and then you put 1.8 rockers on???
What is the dif??? did you think about that?
Old Sep 10, 2005 | 09:42 AM
Byter's Avatar
The XER lobes are causing too much valvetrain noise. I'm not trying to decrease lift, I'm trying too decrease the ramp-up rate of the cam.
Old Sep 10, 2005 | 09:48 AM
vettenuts's Avatar
I have the Boss II in a box right now waiting to go in with the rockers, etc. Haven't installed it yet. I am looking for a good street cam with extra power for 6th gear highway cruising, not a 1/4 mile cam though.
Old Sep 10, 2005 | 11:21 AM
PREDATOR-Z's Avatar
Then just slap some 1.7 Crane rockers on. That will quiet them down a bit and you'll benefit from more power below the curve and a few more at peak.
That 224/228 is one of the best Comp cams.
Old Sep 10, 2005 | 12:01 PM
Byter's Avatar
I agree that its a great cam. I love the way it drives. What I don't like is the "sewing machine" noise. I have replaced the lifters, pushrods (and experimented with different lengths), rockers, and the shortblock. My noise is not a defective part. While the Crane rockers might quiet it down a bit, I believe the noise is caused by the extreme ramp of the XER lobe, which, in turn, either causes lifter deflection and/or valve noise since they are closing faster.
I've experimented with everything else, now I'm ready to experiment with cam selection. For a moment, let's take the 1.8 rockers out of the equation.
1. Does anyone agree with me that the less aggressive Crane lobe will cut down on the noise?
2. Will going to a 228/232 with .551 lift, 112 LSA (110 ICL) affect the drivability and power range that much from the 224/228 with .581 lift, 114 LSA (113 ICL)? And yes, I know in theory that the bigger cam will push the powerband up the RPM range. I'm looking for real world experience in how much.
3. How will increasing the lift from .551 to .583 (for the 228/232, by using the 1.8 rockers) change powerband just for that cam?
Thanks!
Old Sep 10, 2005 | 12:38 PM
eamador11's Avatar
That cam is going to rock the car bigtime! 112lsa is gonna be very aggressive....I had the GM hotcam in my 96, and that was only .525 lift.
Old Sep 10, 2005 | 01:19 PM
Spinmonster's Avatar
I put the crane 1.8's on my stock cam and it was definitely much noisier. They don't quiet anything down. That's from experience.
Old Sep 11, 2005 | 09:00 AM
Byter's Avatar
Rock as in powerful or Rock as in shake?
Can anyone chime in? How about a cam close to this Crane?
Old Sep 11, 2005 | 10:12 AM
vettenuts's Avatar
One thing not mentioned in your signature is the springs you are running. I know the Comp 918's are good springs, but there is also discussion on the Crane site (each advertiser will obviously have their points they will try to get across) that the beehive design is noisier than a standard dual spring design. Any thoughts to going to the Crane springs as well as their rockers?
Old Sep 11, 2005 | 10:17 AM
Byter's Avatar
I'm using the upgraded dual springs that come with the AFR's (PP golds, I think). They're good up to .650 lift.
I know I keep coming up with questions, but here is a central one. Does the Crane cam mentioned above have a less-aggressive ramp up rate than the XER? It's hard to tell because Crane states their adv. duration numbers at .004 while Comp states theirs at .006.
Old Sep 11, 2005 | 10:26 AM
XTrooper's Avatar
No one is really concerned over whether they're quieter than a stock cam with stock valve springs, and stock rockers.
However, if you have an already loud valvetrain with aftermarket cam and valve springs, the Crane roller rockers will quiet things down. That's from revelant experience.
Old Sep 11, 2005 | 10:34 AM
XTrooper's Avatar
I believe that Crane cam, with its longer duration and tighter LSA, is a definite step up from your present cam, irrespective of the less aggressive lobes. Its less aggressive lobes could actually be considered a plus as they'll be easier on your valvetrain and quieter while at the same time the cam is providing more power.
Old Sep 11, 2005 | 10:37 AM
XTrooper's Avatar
This is another good option and one that would save you money and effort.
Old Sep 11, 2005 | 10:41 AM
Byter's Avatar
I'm actually looking for a less aggressive lobe, both in lift and profile. I believe the steep profile of the XER is what is causing the noise. I'm trying to find a cam profile that's less aggressive, but still get the performance and lift that I have with my current cam. That's why I'm looking at the Crane .551 lift cams with the 1.8 rockers. I'm just trying to decide on whether to go with the 220/224 or the 228/232. The 1.8 rockers will bump the durations a degree or two on top of those.
Old Sep 11, 2005 | 10:47 AM
Byter's Avatar
No way. There is no way I'm experimenting with another set of rockers. I've already tried 3 brands (including stock). I know there are benefits to the Crane rockers, but I'm only interested in them as part of the Crane cam package. I've been working on this problem for over a year. I strongly believe its the cam profile. I will go with a cam only experiment before going with another rocker/pushrod only experiment. ... But thanks for the suggestion ...
Old Sep 11, 2005 | 10:59 AM
PREDATOR-Z's Avatar
The comment that 918's are noisier than duals is from my experience wrong (at least in my case).
When I put my PRC's with platinum duals, the valvetrain is noisier now than when I had my 918's. Preload is the same, .060
Old Sep 12, 2005 | 04:43 AM
XTrooper's Avatar
That actually wouldn't be my first choice of action. I was just stating that it was a viable option if you wanted to save yourself some money.
I think you're on the right track with what you're considering.
Old Sep 12, 2005 | 04:56 AM
JL ws-6's Avatar
Race your car!
I think once you stick a cam in a car.. that's it man, there's no avoiding the sewing machine niose, I'd suggest that you get used to it. If you wanna make power, you are gonna have noises like valvetrain stuff..... deal with it, or go back to stock.
Ever hear a solid roller motor, ever hear the noises that makes? The noise that you have now is nothing.. I'm running pretty much the same cam you are, that's not even loud trust me. It is normal... they all do it.
Old Sep 12, 2005 | 08:12 AM
Joe Vinci's Avatar
Did you follow the exact procedure for adjustment? Are you using stock springs? Unfortunately, if they are noiser than stock, you don't have them adjusted properly or something else is making noise. And I can confidently make that statement having a lot of experience with these rockers. We have great instructions on adjusting these rockers on our website. Joe.
