oil pressue question, extremely high
Old Sep 11, 2005 | 09:16 PM
superchannelkev's Avatar
Default oil pressue question, extremely high
ok so what would be causing my oil pressure to be running at 80 - 100psi? recently got my h/c setup done, oil pressure was running around 60 when the inital startup took place, but now after messing with the valvetrain to get rid of tapping oil pressure is sky high. stock oil pump new comp lifters (oem style)
and right now stock pushrods and rockers.. possible i damaged the sensor? any help would be greatly appreciated! Thanks
-kevin
Old Sep 12, 2005 | 05:39 AM
SporkLover's Avatar
did you overfill?
Old Sep 12, 2005 | 06:55 AM
equandt's Avatar
I have the same problem 50 -70 psi. I'd like to know the answer. Mine happened after my cam change as well. I thought maybe Speed Inc reshimmed the oil pump when they put it back on.
Old Sep 12, 2005 | 11:32 AM
not overfilled (double checked just for you ) its odd because last night i fired it up again (3rd time of the night) and it sat around 55-60psi and then jumpedup to 80-100... i dunno maybe a wire is fried on the sensor or something, everything seems (from the basic valve cover off look) fine
Old Sep 12, 2005 | 12:52 PM
ArcticZ28's Avatar
Maybe you got a pump with the overdrive gear mod
Old Sep 12, 2005 | 01:01 PM
if it was only that easy , but its my stock pump with 35,000 miles on it.. im going to mess with the sensor tonight and maybe end up replacing it just to rule it out 100%
Old Sep 14, 2005 | 06:10 PM
ATLHwyRacer's Avatar
what is that?
Old Sep 14, 2005 | 06:15 PM
Venkman's Avatar
Originally Posted by ATLHwyRacer
what is that?
a joke
100psi? Holy Crap.
Old Sep 14, 2005 | 06:20 PM
yea, i think it is the sensor, cuz with the car turned to on and my friend wiggling the plug, the reading would fluxuate from 40psi down to 0 and up to 100 with his just playing with it, its in a position where it is operating normally right now, but i do have a sensor on order just so it doesnt reoccur on the freeway and i freak out...
Old Sep 15, 2005 | 09:44 AM
equandt's Avatar
Where is the sensor located? I would like to do the wiggle test as well.
Old Sep 15, 2005 | 09:48 AM
slt200mph's Avatar
On top of the block in the rear in the center between the two cylinder banks
Old Sep 15, 2005 | 09:49 AM
equandt's Avatar
So I'll need to get my rubber arm out to get to it.
Thanks.
Old Sep 15, 2005 | 10:05 AM
robertbartsch's Avatar
i never reached it with the intake on...
Old Sep 15, 2005 | 10:09 AM
equandt's Avatar
You didn't have a rubber arm, did you?
Old Sep 15, 2005 | 10:21 AM
slt200mph's Avatar
I can reach mine..if you reach it remember it is plastic and you can break them real EZ..then you will be taking the intake off to put another one on..
Old Sep 15, 2005 | 05:51 PM
mine is easy to get at with !AIR and speed inc fuel rails
Old Sep 16, 2005 | 12:06 AM
yobabiesdaddy2001's Avatar
could oil temp have somthing to do with the increase in psi ?
Old Sep 16, 2005 | 12:37 AM
ArcticZ28's Avatar
nah, he was talking ~100 psi, oil temp doesn't account for that.
Old Sep 16, 2005 | 05:55 AM
RedWS6 00's Avatar
Below is an image of the location of the oil pressure sensor, its the verical black cylinder with the white plug on top. Almost impossible to remove with the intake on, as it sits between the intake and the vaccum pipe coming off the intake, be careful when removing the intake and you could snap the sensor off.
Good luck.
Attached Thumbnails oil pressue question, extremely high-intake_off_oil_sensor.jpg
