running with out lid
Old Sep 12, 2005 | 12:06 AM
GDM Z28's Avatar
Default running with out lid
is there any pros to this? a car i looked at had no lid. just an open filter. Also where the filter sits is that the bottom of the lid? it looks like the center part was cut out (unless its 2 pices).....what would have to be done to replace that.
Its hard to explain what i think is cut but the plasic piece the filter sits on....is it one piece or 2? cause it looks like the center was taken out.
Old Sep 12, 2005 | 12:11 AM
SMOKIN01TA's Avatar
you probably saw one with that k&n cold air kit that is just a open filter and the lid isnt used and the center tray of the bottom part is probably removed
Old Sep 12, 2005 | 12:15 AM
GDM Z28's Avatar
he said it had an intake but i think he said SLP.....he told me he removed it cause he didnt like the way the lid looked.....wouldnt an open filter suck in more hot air and cause the IAT's to be higher therefore makeing less power?
Old Sep 12, 2005 | 01:30 AM
ArcticZ28's Avatar
An open filter would first of all bounce around b/c it's not sealed by the lid. Therefore, crap would get under and around it, causing all that **** to get into your engine. Definitely not worth it, with the additional fact that it would be sucking in hot air from the engine bay. The lid is there for a reason, let the GM engineers at least feel smart about this one.
Old Sep 12, 2005 | 01:58 AM
GDM Z28's Avatar
N/M found out the car has a K&N fipk.....it looks just like this
Old Sep 12, 2005 | 02:04 AM
ArcticZ28's Avatar
Now the FIPK is a bit different. It's obviously meant to be that way
Old Sep 12, 2005 | 02:06 AM
Nittany_marine's Avatar
That would be fine, if you ask me.
Old Sep 12, 2005 | 02:09 AM
GDM Z28's Avatar
i didnt know it had the fipk i just thought it had no lid.....im still worried about IAT's though....i might change it back to a lid...i dont know! lol
Old Sep 12, 2005 | 02:11 AM
ArcticZ28's Avatar
Well on that 35th SS it has the ram air package which directs the air coming into the hood into the filter's area so it's not just sucking in air from the engine.
Old Sep 12, 2005 | 02:22 AM
GDM Z28's Avatar
but the car i was looking at has it on a 98 z28
Old Sep 12, 2005 | 02:55 AM
ArcticZ28's Avatar
Unless you have the ram air hood to go along with it, it doesn't yield cooler intake temps b/c nothing stops it from sucking in hot engine air.
Old Sep 12, 2005 | 07:25 AM
GDM Z28's Avatar
exactly.....sow ith a z28 is would make more sence to go with a lid instead of the fipk correct?
Old Sep 12, 2005 | 09:53 AM
ArcticZ28's Avatar
Yea, a lid with the SLP cold air induction is what I run.
Old Sep 12, 2005 | 11:32 AM
GDM Z28's Avatar
well that piece where the filter sits and the lid clips onto was cut in the middle....where the heck can i find a new one of those? whats it called?
Old Sep 12, 2005 | 11:59 AM
ArcticZ28's Avatar
it's just the bottom housing of the air box. People don't buy them cut out like that, they do it themselves. Just take a dremel to it and cut out that middle piece and you're good to go. I also used some tape to seal up around the bottom so it's a straight shot from my slp cai kit into my filter, no air gets in from outside of the housing.
By the way, just realized you're a newb to the LS1 world since your civics. Welcome
