NO COMPRESSION....wtf?????
Old Sep 25, 2005 | 03:45 PM
  #41
strokedls1's Avatar
What I was saying about 180 out was that as long as the dots are lined up it doesn't matter if you switch the cranks compression and and exhaust cycles. You can't have the cam at 12 and crank at 12 or you will have bent valves.
Old Sep 25, 2005 | 04:21 PM
  #42
2xLS1's Avatar
No you won't.
Put the crank dot at 12 and the cam dot at 12. Now turn the crank 1 complete revolution. Where is the cam dot now?
Put the crank dot at 12 and the cam dot at 6. Now turn the crank 1 complete revolution. Where is the cam dot now?
Why is this so hard to understand?
Old Sep 26, 2005 | 03:44 PM
  #43
HASTINGSRJ's Avatar
Well its not that hard to understand....but I am not understanding why its just not firing. Once I get it off the trailer, I can do a compression test on it, and see what its doing
Old Sep 26, 2005 | 03:46 PM
  #44
Ed Blown Vert's Avatar
I still think the valves are hanging open.
Old Sep 26, 2005 | 03:47 PM
  #45
HASTINGSRJ's Avatar
thats what I am thinking...I am thinking that I got the comp R lifters, not the OEM ones....I will find out when I look at them I guess....
Old Sep 26, 2005 | 03:59 PM
  #46
Remember, the other engine fired with the stock lifters and the only thing you changed was the lifters.
You most likely need shorter pushrods.
Old Sep 26, 2005 | 04:05 PM
  #47
2xLS1's Avatar
Go to Autozone and get a $20 compression tester and use it. That will tell you if the valves are not closing.
Old Sep 26, 2005 | 06:44 PM
  #48
Paulz2820's Avatar
hey an ignition module will cause the same thing. it will fire a couple times and stop sending fuel. my car does it every 2 months or so. i'll just come back the next day and it starts fine. i'm almost postive its the module on top of the column. there is an adjustment on there 2 if you lossen the 2 bolts holding it on.
Old Sep 26, 2005 | 06:46 PM
  #49
You should hear it spin. I swear when I heard it, I though the starter didn't engage. And the only thing was spinning was the starter. I was suprised to see the engine spinning.
Old Sep 26, 2005 | 08:30 PM
  #50
strokedls1's Avatar
Depending on the pushrod length, you could shim the rockers up to take away some preload. Now I get what your saying 2xLS1. Had a hard time visualizing it. With no compression it definitely won't start.
Old Oct 9, 2005 | 08:27 PM
  #51
wicked_95z's Avatar
alright fellas...Im helping Rob down in NC and here is what we've got after tearing it down today. We hooked up my vaccum guage and turned it over. Needle didnt even flinch. Hooked up the complression guage, same results. Loosened the rockers on number 7 and left the compression guage hose screwed in the plug hole and blew a lung full of air into the cylinder. I didn't even get a hint of cylinder pressure. I could hear the air coming out. So with that in mind and it being a pretty new engine, I'm thinking the valves are bent. Im not real familiar with LS1s, only worked on a couple, but mechanics are mechanics. However, is there anything we are missing? We only did it on one cylinder but the way the engine sounds when you turn it over we only needed one cylinder. Need you thoughts ON THE PROBLEM AT HAND.
Old Oct 9, 2005 | 08:40 PM
  #52
DaddySS's Avatar
Originally Posted by 2xLS1
I think you using the term No Compression is confusing a lot of people here. Have you checked the "compression" with a compression tester. Are you just trying to say you are getting no combustion as in it's not firing? Sensors have nothing to do with compression. Only piston movement and valve events control that.
Exactly, take a deep breath and tell us exactly what's going on here. No compression as in engine spins too freely or you checked the compression or, the engine turns over but will not fire? Tell us what you know - ie: you checked the compression by at least the finger method, you're getting good spark, etc.
Old Oct 9, 2005 | 08:46 PM
  #53
wicked_95z's Avatar
We checked the compression by the guage method. The engine spins as if the timing chain were broke but the rockers are moving. We haven't checked for spark and we can smell fuel on the plug we took out
Old Oct 9, 2005 | 08:50 PM
  #54
JoeyGC5's Avatar
Pull a head
Old Oct 9, 2005 | 08:59 PM
  #55
P Mack's Avatar
Originally Posted by DanZ28
Also, on the whole 180* out thing, can someone tell me how that could be ok?
You need to realize that is 180 camshaft degrees, not crank degrees. The piston to valve relationship will not change because 180 degrees on the cam is 360 degrees on the crank, one full revolution off.
Old Oct 9, 2005 | 09:01 PM
  #56
P Mack's Avatar
When you pull the rockers and hear air coming out, can you tell if it's coming out the intake or exhaust port?
Old Oct 9, 2005 | 09:26 PM
  #57
GuitsBoy's Avatar
If youre not getting a hint of compression with a rocker pulled, its gotta be bent valves (unless you have a hole in every piston, which is rather unlikely). Time to pull the heads and inspect the damage. My guess is it wont be pretty.
Old Oct 9, 2005 | 09:33 PM
  #58
2xLS1's Avatar
Pull all the rockers off one head. Lay a straight edge across all the valve tips and report back what you find. I think you've already answered your own question, just don't want to believe it.
Looking back at the original post, a short block was installed. Was there a cam already in the block or was a cam installed? Just trying to figure how the cam timing got off and bent the valves.
Old Oct 9, 2005 | 09:52 PM
  #59
wicked_95z's Avatar
Ill have to let Rob chime in on that one
Old Oct 9, 2005 | 11:41 PM
  #60
strokedls1's Avatar
My guess is the cam was installed wrong and at a minimum you have 8 bent intake valves. I hope no major damage was done to the pistons or short block. Pull the heads and let us know what you find.
