Hey, anyone running with a TRex cam?
The TREX will make 15-25rwhp more and will idle MUCH rougher and drive MUCH worse. The f-13 is more like a stock drive, whereas the trex is not. People will argue whether or not a TREX is a daily driver cam, but you will NEVER hear someone argue that with an f-13. You should make anywhere from 390-405rwhp with the f-13+bolt-ons. The same car would make anywhere from 400-425rwhp.
Manny
With a proper tune a TREX can be made to drive like stock. And I do want to stress that is with a proper tune. I have done a couple of cars that have no bucking, surging, or any other nasty habits with this cam, just a radical idle and lots of power.
Tuning this cam to drive properly is definitely more involved than some of the smaller offerings out there, but it can be done.
I concur with Geoff.not a daily driver here .this thing have a nasty idle.idling @950rpm.rev limiter @7200rpm.
http://www.ls1sounds.com/mufflex/muf...am_950idle.wmv
It sounds like a pro-stock car at idle, so if you want to scare people into thinking your bad ***, this is the cam for you. But you can really drop the hammer in this thing too!!!
Plus, the term "streetable" depends on one thing. If you dont mind driving it, then that makes it streetable.
I will say this though, if it is an M6 you are gonna need some serious gears, that powerband will give you jack crap off the line...but you will be able to over spin your crank with no problems on the high end side!
Get your rev limiter set somewhere reasonable cause if you miss one to many shifts = game over. Especially if it is stock internals.And yes...you will be able to get that thing deep into the 7,000's.
my $0.02
PS:
How the hell does he get that car to pass inspection in freaking California!?
my $0.02
PS:
....ehem 250$
....ehem 250$
