ET Performance flow numbers and impressions
BTW, I think I've got something for you
The above statement is why the NEW LS7 intake and head design looks way more interesting to me. Until then I choose to use nitrous with my stock LS1 cathedral heads
I'm guessing with my hydraulic roller 408 peaking at 6300 I would probably want a 255. Are 11* always going to benefit power?
I've searched but not found this info anywhere, THANKS!!
215---mild 5.7 street stock style manifold 2.040 intake valve. 320 peak flow
225--- this will be the most common ls2 replacement and 5.7 for the guys that can get by the myth that 225 is too big for a 5.7. 2.080 332 peak flow
240--- this port is very universal, hot 5.7 but would work est on a power adder 5.7 or a 500 plus rwhp 402. I would at the least use a fast 90/90 setup with these, a carurator would be grat too. 2.080 or 2.100 valve is the option,
346cfm peak intake airflow @ .675 lift
255---this is our hottest cathederal port head using stock style rocker arms. it is very similar to the 265 but still has a restriction around the intake pushrod hole. 2.100-2.125 valve size. this head is good for a real hot 402 or larger, avalible with any bore size, it would be great on a 427 street car. this cylinder head peak flow is 360 at .675 lift. not too far off from the LS7.
265--- This a good large cubic inch cylinder head. or a very high rpm small cubic inch . this configuration uses a rocker arm system very similar to the c5r, the rocker arm boolt downs are moved to a c5r configuration and uses a 7/16 bolt down this head has seen the 380 cfm range, but is sensitive to valve shape and seat angles. most of our pieces come off the machine in the 370's which is still very stout. 2.100-2.125 valves are standard with a 1.570 or 1.600 exh.
hope this helps
BTW we are still developing our new intake manifold to really take advantage of these higher flowing versions. I hope to have a prototype at the pri show.
and for the corvette guys that have viper friends, we also have our new "Viper STRIKER" cylinder head avalible in october.
www.etheads.com
cool news on the intake, I had no idea on that either
hope this helps
