ET Performance flow numbers and impressions
Old Sep 18, 2005 | 07:25 PM
  #41
Cary@Perf-Induction's Avatar
Collections Hold
Default ok
thanks for the feedback. even as much as we work on this project every day of the week, we could still use recomondations and requests.
thanks,
ETP
Old Sep 18, 2005 | 08:06 PM
  #42
Mrbowtie26's Avatar
How do these heads compare with the AFR 225 head? I am doing a LS-2 402 buildup with a fast 90/90 setup. I already ordered my AFR 225 heads 2 months ago from AFR and they were supposed to take 4-5 weeks and I'm starting to get sick of waiting. Nobody that I called has the AFR 225 heads in stock either. I may just get a refund and look into another type of head but not sure on my options.
Thanks
Ron H.
Old Sep 18, 2005 | 08:38 PM
  #43
Brandon Boomhauer's Avatar
mrbowtie, from the flow numbers they are outdoing the afrs.
Cary/ETP I'll agree with JRP, keep that handy, and a good writeup of volumes/options/etc/etc w/ retail pricing would be greatly benificial.
Could even be setup in a table (or on your website, as a table) so it coudl easily be transfered here..
-Brandon
Old Sep 19, 2005 | 11:34 AM
  #44
Mrbowtie26's Avatar
[QUOTE=Brandon]mrbowtie, from the flow numbers they are outdoing the afrs.
The flow numbers on the intake is very good but it seems the flow on the exhaust is less than the AFR head. Any idea if the flow on the intake side is more important. I see that the biggest valves that the ET 240 heads come with on the exhaust is 1.57.
Thanks
Ron
Old Sep 19, 2005 | 11:43 AM
  #45
look at the #s with a pipe and compare.
i would imagine they could do a bigger exhaust valve if you wanted that.
Old Sep 19, 2005 | 11:44 AM
  #46
Wet 1's Avatar
[QUOTE=Mrbowtie26]
Thanks
Ron
Part of the reason is AFR is using a pipe, ET is not. Add the pipe and watch the flow increase considerably (+20-30).
Old Sep 19, 2005 | 01:03 PM
  #47
xxxhp's Avatar
Originally Posted by cary et performance
BTW we are still developing our new intake manifold to really take advantage of these higher flowing versions.
Now that's what I want to hear about
Can you elaborate more on this?
Old Sep 19, 2005 | 11:48 PM
  #48
Worm's Avatar
Wow, nice heads.
Old Sep 20, 2005 | 12:28 AM
  #49
98M6SS's Avatar
Any chance these will get CARB approval? Great results, by the way!
Old Sep 20, 2005 | 02:15 PM
  #50
pdd's Avatar
pdd
heads look sweet
Old Sep 20, 2005 | 08:22 PM
  #51
52172's Avatar
On our 11 degree heads 215,225,240,255 all use stock rocker arms with the exception we supply a billett rocker arm pedestal to properly align the rocker arms and the height. If Scott or Brad get their pics up here shortly, maybe they will put those in too. But they are not offset. Our 265 does use an offset rocker (avalible from Jesel) Racer net at 1430.00 for the mohawk series. We will offer them cheaper with the cylinder head purchase. All of these will fit a stock style manifold as well. Our LS7 is very similar to the GM LS7. We offer them set up fot the Jesel C5R style rocker right now until the GM rockers are readily avalible. the price on 225 fully assembled with SEVERE DUTY valves and hyd. roller springs is 2475.00 C5R and LS7's will be under 3500.00 complete
I am a little confused your 11 deg ls1 heads are not ls7 heads right? I see you are mentioning ls7 heads do you have them now I thought they are not a vailable until the first of the year or so? What is the difference between your 11 deg head and the new gm ls7 head coming out other than the ls7 intake ports are totally different and they need the ls7 intake to work. What do you mean when you say our ls7? Do you call your 11 deg ls1 heads ls7? Are they your own casting design? Thanks for clearing this all up.
Old Sep 20, 2005 | 08:30 PM
  #52
Beast96Z's Avatar
As stated in your other thread, the heads are new castings. They have a LS-7 design, along with a C5-R and LS-1 designs. All the diffrent sizes 215, 225, 240, 255, 265 and so forth are LS1 design wearas the LS-7 is just that, the LS7 design. If you go to there sight www.etheads.com you can see the LS7 sitting with the LS1 style on the homepage.
Old Sep 20, 2005 | 08:45 PM
  #53
52172's Avatar
thanks for clearing it up.
Old Sep 20, 2005 | 09:29 PM
  #54
52172's Avatar
so their ls7 head is a copy of gm's head?
Old Sep 20, 2005 | 09:56 PM
  #55
jerflash's Avatar
hey cary i was looking into your 215s for my 347 which already has the f13 in it and i saw you have 2 versions....the 11 deg and the 15deg
i saw the flow numbers and noticed that at.400 to .600 lift the number are the same but the new angle helps in low lift and very high lift areas
so with a cam that is below 600 lift these heads would not be a big improvement over the 15 deg heads
what do you think?
Old Sep 21, 2005 | 03:02 AM
  #56
Collections Hold
Default numbers
what do you think?
Our 11 degree actually flows a bit better than the flow model numbers posted on the website, we have made some valve and seat angle/combustion chamber changes that increased the 215's /11 degree.
all and all the 11 degree has other features that would make them a choice over the 15 degree. other than airflow.
Old Sep 21, 2005 | 12:35 PM
  #57
jerflash's Avatar
sounds cool man
which heads would you go with for a f13 cam
230/232 595/583 on a 112?
thanks
joe
Old Sep 21, 2005 | 12:59 PM
  #58
Nate_Taufer's Avatar
Is there a price breakdown somewhere. I checked on g-force's site and saw nothing as well as the etp site.
I am basically just looking for a set of the 255's for my next project.
Nate
Old Sep 21, 2005 | 01:11 PM
  #59
52172's Avatar
yes it would be nice to see actual prices somewhere. I would like to see prices on the ls7 heads and intake? And a price for the new intake coming out for the ls1 heads?
Old Sep 21, 2005 | 01:54 PM
  #60
ls1nos's Avatar
Default prices
Call Brad at force Fed High Performance He will give you prices and a they are a good price
