Bad Oil pump?
Bad Oil pump?
Ok so I beating on my car racing some nissan 240sx with an Sr20det, and when i get back I notice my oil pressure is kinda low and start to hear a ticking noise from the valve train. The tick noise gets louder as rpm's go up. So figure its time for a no oil pump. Does sound right I just want to make sure this is my problem. My car as 56xxx miles on it. Oh ya any sugguestions for and aftermaket oil pump and timming chian? Thanks in advance,
Brian R.
Brian R.
Brian R.
Brian R.
Yeah I plan on swaping all that stuff out since I think the pump has gone south. I heard about 98 ls1's haveing that problem. The race went good by the top of thrid gear I started pulling pretty good.
yeap that would sound like the problem to me, your lifters are not getting pressurerized so the tapping is the excess clearance between the valve and the rocker. Plus the 98-99 models are known for the weak oil pumps.
CammedTA,
Just curious, what kinda numbers are you putting down because you and I have pretty much the same mods, including the same cam.
I swapped out my oil pump when the cam was done.
Manny
Manny
Oil pumps
Not to hi jack this post but we had some pumps that we coated for a local LS engine building shop that has since gone south. These are blended and ported, been oil shedding coated on the exterior and the pump gears are coated to improve oiling and life. We will sell these for $85.00 plus shipping. GM parts nubmer 12586665. Thanks
777, could you explian what else could be wrong. The oil pressure was at like 40 psi, under normal driving condtions I only went a couple of miles before I noticed it was lower than normal. The rpms never got above 2500 and the ticking sound was comeing from the heads.
