questions for 1.8 roller rocker owners
Originally Posted by Dan_the_C5_Man
Looks like more "issues" with the 1.8 rockers.. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Originally Posted by vettenuts
You bent valves? Do you know how and when that happened?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
example
220/230 .581./.581 lift with 1.7 rockers
214/224 .581/.581 lift with 1.8 rockers.
both basically have the same effect at the valve. but, the with the 1.8 rockers, the lifter. pushrod, and rockers isn't moving as fast.
I put up a new post over in the dyno section. I don't believe the drop off at 5,900 is valve float. On the one run up to 6,600, I think I had float at 6,400. Crane's web site verifies that this is likely as they call for float at 6,600 with 1.7 rockers.
Greg,
What cam are your running, I don't see it in your earlier post?
Greg,
