Who has used ARP head BOLTS?
Factory bolts are not torques to spec. They are torqued to yield which means you torque it to 22ft lbs. Then you go around the 10 large bolts and turn them 90 degrees. Then you go around and then turn 8 of the longest one to another 90 degrees and the remaining two outside short head bolts 50degrees.
Dixit
Dixit
