lq9 vs ls1?
Old Oct 3, 2005 | 06:00 AM
peppersac's Avatar
Default lq9 vs ls1?
i am looking to get some heads for my 5.3l, i can find the 6.0l lq9 heads cheaper than the ls1 or ls6 heads. does anyone know the major diffrence, or which one would be better?
Old Oct 3, 2005 | 04:40 PM
peppersac's Avatar
Old Oct 3, 2005 | 04:56 PM
Steve Bryant's Avatar
LS1 Tech Veteran
The deck of the 317 (LQ4/LQ9) is a little thicker to yield a combustion chamber of that is about 72 cc's rather than about 60 cc's (as I recall) for the 243 LS6 casting. Otherwise, they are virtually the same. Since you are running a supercharger with 6 PSI of boost, I'd recommend the 317 castings and keep your static CR about 9.4:1. That way you won't have such a problem with detonation under boost. The valves and flow rates for the two heads are very similar.
Steve
Old Oct 3, 2005 | 09:36 PM
peppersac's Avatar
thanks alot!!
Old Oct 3, 2005 | 10:18 PM
SPD KILZ's Avatar
Steve
Exactly
