Which should I get first H/C or clutch?
I have an '02 M6 WS.6 with full exhaust (LTs, ORYP, corsa cat-back) and lid....I am saving up some money right now...but I don't know whether it is better to get a good clutch (e.g. Mcleod twin disk, ram, etc.) even though my stock Z06 clutch is fine or whether I should get a heads/cam combo first...would the stock clutch hold up for some time with a set of TEA S2 and TR224?...this would probably put me over 400rwhp...right now I have 345rwhp/355rwtq...
thanks in advance...
Rayo
Rayo
Re: Which should I get first H/C or clutch?
If you go to the track alot definitely clutch. If you are on the street most of the time the 02 Z-06 will last a little while on street tires with 400+RWHP.
Good luck,
Chris
Good luck,
Chris
I agree with Chris, get the H/C first if you plan on staying away from the track with drag radials or slicks. If you run street tires like I am, you should be fine for a while. I'll let you know when my clutch goes, I've got the exact same setup as you are getting.
WARNING!!!! My first trip to a slippery track with street tires after bolting on my S2 heads was enough to kiss my ZO6 clutch goodbye <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
