solid roller lifters
Old Oct 7, 2005 | 04:53 PM
racer7088's Avatar
Originally Posted by MUSTANGEATER
I don't see why they wouldn't hold up to that? Then again I haven't put that much seat pressure on mine. I don't know anything about the new lifters coming out, although I do know comp, cam motion and Isky are using the Morel lifter stuff, and not just on the LS1's.
There are many different lifters that Morel does with other companies in part or whole and there are some different wheels they use. Isky has a Redzone solid roller lifter and a regular solid roller lifter. The Redzone is the one for much higher pressures and has a captive tiebar. The regular LS1 drop-in Morels can spin in the plasic lifter bores if they are melted or get older. The customer in question wanted the most fail safe lifter possible and that is what is on the way.
I have probably the best price on the Morels also so PM me if you want a price on the regular Morels as well.
Old Oct 7, 2005 | 11:38 PM
427's Avatar
427
Jesel makes the lightest lifter we have found for the LS engine. They are very durable but kinda pricey.
Kurt
Originally Posted by stevewix
who has the lightest/nicest solid roller lifters out there? any bad experiences?
Old Oct 8, 2005 | 10:42 AM
BTL FED's Avatar
I love my Jesel's
Old Oct 8, 2005 | 11:41 AM
DAPSUPRSLO's Avatar
I would definately choose to run the jesels if the ones I have were the right size and had the proper oiling restriction. $1600 for block bushing is just not in the cards right now when I can just offload mine and get a set that will work with the stock lifter bore.
Old Oct 8, 2005 | 06:32 PM
racer7088's Avatar
Arrow
DAPSUPRSLO,
I have a set of Jesels like BTL FED has there if you are interested since the owner was looking to go link bar and not use the GM plastic lifter trays like those Jesels do.
Old Oct 8, 2005 | 06:49 PM
DAPSUPRSLO's Avatar
Originally Posted by racer7088
DAPSUPRSLO,
Pm me a price Erik, assuming they are .842" diameter and have the restrictor for proper oiling? Maybe you'd be interested in a trade for the ones I have now. Thanks.
