G5x4 Cam
Old Oct 11, 2005 | 03:45 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, you cant be a "cheap bastard" and go with a big cam without certain supportng mods. I learned the hard way with a 244/248 with 3.42's. and those cams will pull more than you want to spin your bottom end most likely. If you search around, you will find that there are plenty of people cracking into the 11's without a ginormous cam.
Old Oct 11, 2005 | 04:38 PM
formulajunky's Avatar
Thanks for all the imput so far, some of this has changed what i was thinking. I guess i'll keep searching
Old Oct 11, 2005 | 04:47 PM
DONAIMIAN's Avatar
Personally I think an X2 would be a good choice for you.
Old Oct 11, 2005 | 04:53 PM
camaronut502's Avatar
so will a ms3 on a 114 clear stock heads with a problem?
Old Oct 11, 2005 | 05:05 PM
But will the X2 give me the power i was looking for... The specs sounds good to me
Old Oct 11, 2005 | 05:06 PM
DONAIMIAN's Avatar
you should be going 11's all day long with that cam.
Old Oct 11, 2005 | 05:08 PM
OK well i'll look into that cam Who sells those, and will having only a 3500 stall be ok?
Old Oct 11, 2005 | 05:24 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
TSP http://texas-speed.com/item_detail.asp?ProductID=1272
LGMotorsports http://www.lmperformance.com/4931/1.html
Best bet is to wait for someone to sell on here, $500 for LG cam sounds like it might be out of your price range if you are trying to do some cheap good mods.
Good Doctor's Avatar
LG sells the x2 (same sponsor who sells the rest of the g5x-series cams)
www.lgmotorsports.com
Old Oct 11, 2005 | 05:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yes there is no clearance issues with the 114 MS v.3. Heck... A 113 will clear with unmodified heads.
Old Oct 11, 2005 | 07:15 PM
blkZ28spt's Avatar
AFAIK the MS3 is on a 113 and that's the only way they grind it.
It, of course, easily fits under stock heads.
Old Oct 12, 2005 | 01:23 PM
  #32
John02SS's Avatar
From what it looks like, the X4 might be a little big for you. I have one and I know the "Actual Specs" on it. It is healthy! The MS3 and X3 are very very close. A cam that big takes some supporting hardware to make it work. If you don't want to restall, regear, and look for a good tuner I'd stay with some in the low 230 duration. That will easily get you in the 11's and will be easier on the bank account.
John
Old Oct 12, 2005 | 04:14 PM
  #33
Yeah i don't really wanna Restall or regear, But Of course i'll have it tuned have a buddy that does it so thats not a problem
Old Oct 12, 2005 | 04:27 PM
  #34
s346k's Avatar
where does this cam peak on stock heads? i can't really see tuning becoming an issue as many t-rex cars are tuned and provide decent driveability. i am dead set on this cam, after much homework, etc. but it's hell finding a dyno graph of this cam where there isn't something affecting it's true numbers. ie tires rubbing the fender wells or bad o2 sensors, etc. also, this cam will pull to ~7k on stock heads, correct? i've only found 2 dynos on here, both of them showed hp dropping off HARD like 150 rpm after peak...
Old Oct 12, 2005 | 04:28 PM
  #35
X2Z28's Avatar
G5X2 and a 3500 stall.......definately the way to go in my opinion
Old Oct 12, 2005 | 04:33 PM
  #36
ok well the x2 sounds good guys if that gets me the 11's and the power i'm looking for Its all good thanks for all the imput thats really cool, I'll look into that thanks again guys
Old Oct 12, 2005 | 05:30 PM
  #37
DONAIMIAN's Avatar
Thats what were all here for, be sure to post results when your all set.
Old Oct 12, 2005 | 06:05 PM
  #38
LS1SS4ever's Avatar
Talking
The first cam sounds great
Old Oct 13, 2005 | 06:02 AM
  #39
Checkmate's Avatar
Originally Posted by Jimmy P
The G5x4 actually idles prety nicely. From what I have heard, much better than the X2. Mine idles at about 930-1030. On a cold start, the rpms will be all over the place, from 750-1300rpms. But after a minute, it will idle almost like stock. It never dies out. It would once in a while at first, but then I changed both O2 sensors and now it never stalls. The tuner himself was suprised how nicely it idles.
With more cold idle tuning it will start and hold the requested RPM. Just needs more adjusting.
Old Nov 4, 2005 | 02:42 AM
  #40
strokednsprayed408's Avatar
I bought an G5x4 for mine before i decided to go stroker, but I havnt installed it yet, talked to matt at LG motorsports and he gave me the specs. It's around 242/246/ 608/612 lift on a 111 LSA. AZ power & sound used it on a stock block w ls6 heads, and dynoed like 440rwhp. It's a bad *** cam and I hear it's pretty streetable. They did 70mph in 1st w stock gears in a 6 spd.
