solid roller???
in the long run it would be better to get the adjustables co account for any future cam, lifter, head decking, block decking, changes you may decide to implement. plus the parts my wear just a little over time too causing more lash to show up. I would think you would definately want the adjustables.
One thing about the Patriot/DRE..the shaft is a little smaller in diameter...so when you go to tighten them down..you have to be sure BOTH intake and exhaust valves on that set you are installing are on the base cirlcle. Otherwise you will snap the shaft. Its very important to remember this when REMOVING them...especially if you are used to stock rockers setups and just zipping them off there...you may forget. Really that goes for all shaft mount rockers...but the DRE ones just have a thinner shaft that will snap. Dont ask how I know this
one of my main ?? is how streetable is a moderate to a mild extreme settup? i will have a nother car to drive and take trips in but i love my truck and love driving it. so i would drive it a lot in town and accasionaly on a road trip? is this feesable or should i stay hydrollic?
thanks guys
O and 383 you are the cause of this. i watched the video of your car like 10 times of when you just took it out for a test spin.
For instance, my springs are 1.550'' duals with 250ish seat and 650ish open pressures. More RPM = more pressure.
