ls1 heads
Old Oct 26, 2005 | 03:11 AM
FormulaFirehawk520's Avatar
Default ls1 heads
whats the largest CFMs the you can port stock 853 heads? someone told me they were able to get 305 CFMs but just wondering on others input thanks
Old Oct 26, 2005 | 03:19 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not sure on those heads. Probably not for the good to try and get 305 out of them.
Old Oct 26, 2005 | 03:25 AM
how come? im kind of just starting to understand cam and head concepts
Old Oct 26, 2005 | 03:29 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Your best bet would be to go with some 6.0L heads
Old Oct 26, 2005 | 03:31 AM
i know i should but see heres the thing im really cheap and besides im trying to go as stealthly as i can
Old Oct 26, 2005 | 04:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What is not stealthy about the LS6 heads?
Old Oct 26, 2005 | 09:27 AM
SUTTERERMAN85's Avatar
6.0 L heads have a larger Combustion Chamber and that would lower it compared to stock. would be great for FI. you should get some 243's if you get ls6 heads not the 317's or whatever they are. just my .02
Old Oct 26, 2005 | 12:14 PM
DONAIMIAN's Avatar
305 out of an LS1 head is doable. Ive heard some people getting and lot more out of an all out race LS1 head.
Old Oct 26, 2005 | 12:22 PM
xfactor_pitbulls's Avatar
Well the 853 head is no different from a 241 casting or even a 852 truck head. Combustion chamber is the only thing that changes there. It isnt uncommon to see 300+cfm out of them. I believe TEA claims 318 cfm up top from the stage 1.5 I have seen Trevor Johnson's work go about 320 in person and my own has been 305. So by no means is it a big deal.
Brandon
Old Oct 26, 2005 | 02:05 PM
Brandon
if i were to get around 305 cfm should i replace the rockers or leave them stock
Old Oct 26, 2005 | 09:12 PM
anyone???
Old Oct 26, 2005 | 09:14 PM
Leave the rockers alone, period. You will see absolutley no gains. That is unless you are sliding in a .700 lift solid roller cam.
Brandon
Old Oct 26, 2005 | 09:16 PM
Brandon
cool thanks
Old Oct 26, 2005 | 10:29 PM
52172's Avatar
Mine flow 306@.650 and 299@ .600 and my head porter said he can bring them up to 330 cfm@.650 if needed for larger cubes.
Old Oct 27, 2005 | 07:56 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I guess they are able to flow more than i was thinking!
Old Oct 27, 2005 | 08:31 AM
I would like to see that from a set of 241/853 heads. Sounds like smoke to me.
Brandon
