Need Pics of Block Clearance on 383 SBC.
Old Jan 15, 2003 | 08:43 PM
The Guy in MY 99TA's Avatar
Default Need Pics of Block Clearance on 383 SBC.
I baught an Eagle 4340 Steel Crank today from a place in Jackson, MS. Jegs had it priced for 679.99 and I got this crank for 499.99!!!! I saved about 200 bucks on it all together! I was very happy!
Now I need to know about how much machine work I am looking at to make it work right.
Josh S.
Old Jan 16, 2003 | 01:43 AM
SStrokerAce's Avatar
Default Re: Need Pics of Block Clearance on 383 SBC.
You need to get a new set of bearings and put the crank in the motor, spin it around with a rod on it and find where it hits. Most times it's on the lower part of the cylinder along the oil pain rail. You can machine that out with a mill or with a die grinder. I have one done in the shop right now but no digital camera on me to take a pic.
Bret
Old Jan 16, 2003 | 08:03 AM
HITMANSS's Avatar
Ditto that. I have one sitting in my garage, & might be able to take a pic at lunchtime. If so, I'll post it this afternoon.
Old Jan 16, 2003 | 07:11 PM
I guess I'll need to use the bearings(considering that rings shouldn't be needed on the pistons)that I plan on using right?
I might just get the guy that I'm getting to do all my balancing and stuff to clearance it for me but I'de like to get an idea of what needs to be done b/c if it isn't a WHOLE lot a grinding I'll do it myself.
Josh S.
Old Jan 16, 2003 | 08:45 PM
It's about 1-2hours worth of work. If you have a compressed air powered grinder and a respirator you can do it, if not leave it to him. It's dirty work.
Bret
Old Jan 21, 2003 | 09:56 AM
HITMANSS's Avatar
Here is a pic of the relief needed for a 383. The semi-circular indent right above the rod end is what needs to be ground, or the rod end will hit the block.
http://www.jrfarrar.com/~hitman/images/Mvc-005f.jpg
Old Jan 21, 2003 | 11:46 AM
RedBaron's Avatar
I didn't realize that you could use a SBC crank in a ls1. Is it as easy as dropping it in and checking for clearance?
Old Jan 21, 2003 | 11:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
SBC stuff will not work in an LS1.
Old Jan 21, 2003 | 01:09 PM
HITMANSS's Avatar
The thread says SBC --- the pic is from an SBC.
Old Jan 21, 2003 | 02:01 PM
CW 99 Z's Avatar
Some blocks dont need any clearancing at all. The 383 I built for my 72 nova didnt. This was a 74 2 bolt block with splayed billet caps installed. Also I used 5.7 inch rods. The only problem I had was a couple of the rods hit the cam. Just had to grind a little off the balancing pad on the big end of the rod. I would say just put it together without the rings and see what all hits. If it looks like more than you want to tackle let the machine shop do it.
Old Jan 22, 2003 | 12:09 AM
RedBaron's Avatar
Didn't think so.
Old Jan 22, 2003 | 12:11 AM
RedBaron's Avatar
Didn't think so.
