Trickflow vs AFR on 3.90 bore flow numbers
Old Nov 2, 2005 | 07:28 PM
Brian Tooley Racing's Avatar
Wink Trickflow vs AFR on 3.90 bore flow numbers
Just had a chance to flow the new TFS LS1 head, it has a 13.5 degree valve angle and relocated spark plug to enhance the mid lift flow with a smaller valve, these had 2.04/1.57 valve diameters. This is the most impressive head we have seen on a 3.90 bore. The chamber measures around 3.950" across, so it is designed to be optimum on a 3.90 bore. All flow numbers off our bench.
Lift............AFR 205...........AFR 225...........TFS 215
.100............64...................68........... ........69
.200............140.................149........... ......139
.300............203.................220........... ......219
.400............250.................269........... ......261
.500............282.................306........... ......304
.550............296.................315........... ......314
.600............303.................305........... ......325
With this head having this much all around flow and being designed specifically for a 3.90 bore we anticipate it should be the most powerful 3.90 bore head money can buy, and it has TONS of piston to valve clearance. It has about .050" more P to V then our 5.3 Stg 1.5 head. I have flow numbers off the new Dart heads, but they were not as good as the AFR 205. Enjoy!
Almost forgot, this is with absolutely NO hand finish work.
Old Nov 2, 2005 | 07:47 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Intriguing...have they released a price on these yet? What do you use for rocker arms?
Old Nov 2, 2005 | 07:53 PM
MadBill's Avatar
What do you use for intake port radius? Your 225 AFR data is substantanily lower (305 vs. 320) @ 0.600" than their posted numbers: http://www.airflowresearch.com/ , but the rest of the 225 and the 205 data is similar.
Update: Oops! I see they test the 225 on a 4.125" bore...
Old Nov 2, 2005 | 07:55 PM
MeentSS02's Avatar
The 225s he had were on a smaller bore than what I'm seeing on their website - 3.90 (Brian's) vs. 4.125 (AFR's).
Old Nov 2, 2005 | 07:57 PM
MeentSS02's Avatar
Looks like you caught that too...I'm definitely liking the idea of having something optimized for the 3.900 bore considering I just don't have the money (nor do I want to spend the money) for a larger bore engine.
Old Nov 2, 2005 | 08:34 PM
Raife's Avatar
when can we order a set?
Old Nov 2, 2005 | 08:38 PM
distortion_69's Avatar
Agreed.. and at what price?
Josh
Old Nov 2, 2005 | 08:49 PM
Steve Burger's Avatar
LS1TECH Sponsor
Will the price be inline with Dart?
Old Nov 2, 2005 | 08:52 PM
WS6FirebirdTA00's Avatar
hmmm, thats nice. id like to see some more compairison to afr getting these on the dyno, as well as a price.
jrp's Avatar
jrp
SN95 Director
where's the 280cfm exhaust numbers
MeentSS02's Avatar
I'd doubt it, but I'd sure hope so...they'd sell like hot cakes.
Old Nov 2, 2005 | 09:07 PM
J&J Speed Shop's Avatar
Do you use the SF600, 1020 or something different? Also what about the exhaust numbers?
Old Nov 2, 2005 | 09:11 PM
didnt even pay attention to that. lets see them too
Old Nov 2, 2005 | 09:12 PM
jrp's Avatar
jrp
SN95 Director
they use an audie/flow data bench, not SF.
Old Nov 2, 2005 | 09:16 PM
Nine Ball's Avatar
LS1Tech Co-Founder
It doesn't matter what brand flowbench they use if we are comparing data that was measured on the exact same flowbench for each item. You guys are too critical, quit flowbench racing
Old Nov 2, 2005 | 09:29 PM
dragon93308's Avatar
Just price them about $1200-1300 bucks (summit price) and you guys will take over the market for the normal street heads/cam guys
jrp's Avatar
jrp
SN95 Director
you have any pics of the heads brian, and what springs are they using?
Old Nov 2, 2005 | 09:33 PM
also what is the p-v clearance vs afr 205 heads?
Old Nov 2, 2005 | 09:34 PM
Josh's Avatar
I'd like the see the exhaust numbers as well.
Josh
Old Nov 2, 2005 | 09:55 PM
Full-Force's Avatar
Do you know what the combustion chamber and intake runner volume is?
