Short Block is 90% done...
Old Nov 9, 2005 | 07:21 PM
gollum's Avatar
Phil, You may need this also.
Old Nov 10, 2005 | 01:45 PM
1fastWS6's Avatar
That timing chain looks like a motorcycle drive chain! Short block looks good!
Old Nov 10, 2005 | 06:27 PM
67Ranger's Avatar
Low compression 6.0 bored .030 over. Scat forged rods, speedpro forged aluminum pistons, arp main studs, all new clevite bearings, new timing chain, and a bunch of other odds and ends. This is my first time, so ive been trying to do my reserch, and hopefully everything will work out in the end.
Old Nov 10, 2005 | 08:38 PM
SSilverSSurfer's Avatar
whats thermal coating the pistons help out? shortblock looks good....good luck on the numbers
Old Nov 10, 2005 | 09:59 PM
Phil99vette's Avatar
7 Second Club
Everything I have read says that by coating the pistons and chambers it reduces detonation by evening out the burn. All of the top engine guys I have talked to said it works!
Phil
Old Nov 10, 2005 | 11:55 PM
well then i guess that explains it all
Old Nov 11, 2005 | 12:47 PM
bulletLS1's Avatar
I followed the instructions THAT CAME W/ THE BOLTS, (arp instructions), unfortunatelly I dont have a strech gauge.
everything is done, exept for the timing chain, turning over by hand I felt a noticeable bump that required some more torque to turn over, (gulp!) I expect the piston has a litle rock in its bore (only one piston BTW),
when I left the assembly for about two days then turning over required GREAT effort, I though I might bend a rod (by hand hahahahahaha!).
I used assembly grease liberaly in bearings, everything is oiled, cyls are wet...
SORRY FOR STEALING THE THREAD!!!!!!
GOOD LUCK!!!!!!
Old Nov 11, 2005 | 01:22 PM
VINCE's Avatar
Shorty Director
Originally Posted by Phil99vette
If I had the money, the chambers, valves and exhaust runners would be coated also.
Phil
What do you mean if you had money? You have money..
Old Nov 11, 2005 | 01:28 PM
7 Second Club
I have the money just don't have the money. Hey did you ever get your HP EIO?
Phil
Old Nov 11, 2005 | 02:42 PM
Ragtop 99's Avatar
I understand the thermal coating for the pistons but is the coating a lower friction surface than metal? Just wondering what are the benefits on the bearings?
BTW, nice, very nice...
Old Nov 11, 2005 | 02:49 PM
7 Second Club
The coating on the bearings helps to reduce friction as well as gives you a cushion if you lose oil pressure. A coated bearing will last longer than a uncoated bearing if you lose oil pressure. If you lose oil pressure or it drops the coated bearing won't spin as easy.
Phil
