Short Block is 90% done...
Old Nov 8, 2005 | 08:10 AM
Phil99vette's Avatar
7 Second Club
Default Short Block is 90% done...
Tonight I worked late to get the shortblock done. Basically its done except for covers. Here's what we used:
LS6 Block Bored 3.905
LSx 3.622 Crank
Scat H beam Rods ARP 2000 Bolts
- Torqued 70 ft/lbs - Clearance: .0022-.0024
- Clevite H/Calico Coated Rod Bearings
Diamond -4.2xcc 11 degree pistons
- Calico Coated Skirts and Thermal Coated Domes
Katech Main Caps
- Torqued 60 / 50ft/lbs - Clearance .0017-.0019
- Clevite H/Calico Coated Main Bearings
ARP Main and Head Studs
How's that sound?
Phil
Old Nov 8, 2005 | 08:22 AM
FastKat's Avatar
Sounds like a solid build! What's up with the SCAT rods... haven't heard much about them for the LS1's.
Old Nov 8, 2005 | 08:53 AM
SAM98WS6's Avatar
Did you run back over all the ARP bolts after they sat for while? Mine took another 1/4 turn and Im told thats common.
Old Nov 8, 2005 | 09:10 AM
7 Second Club
I'm gonna retorque all the bolts tonight.
Phil
Old Nov 8, 2005 | 09:17 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
7 Second Club
Let me say this, I couldn't have done this without Jason @ Texas Speed & Performance. He has helped me every step of the way.
Phil
Old Nov 8, 2005 | 09:42 AM
HartAttack's Avatar
LSx 3.622 Crank
Katech Main Caps
How's that sound?
Phil
About how much money did it cost to do this to your motor?
Old Nov 8, 2005 | 10:12 AM
7 Second Club
Call jason @ TSP and he will set you up.
Phil
Old Nov 8, 2005 | 10:39 AM
LOnSLO's Avatar
Nice Phil. WHen you get ready to prime the motor, keep an eye on how much oil is coming up out of the pushrods. That should let you know about any lifter issues.
Old Nov 8, 2005 | 11:06 AM
bulletLS1's Avatar
MINE TOO!!!!
Just waiting for the timing chain.....
I also have ARP 2000 con rod bolts, but at 40 Ft/lb (OEM Rods)
I did not have a strech gauge, and followed instructions (40 ft/lb three times)
Why so high (70)
I have .015 main bearing
clevite 77 performance for rods (CB-663 HD)
GOOD LUCK!!!!!!!!!!!!
Old Nov 8, 2005 | 11:13 AM
7 Second Club
The instructions said to torque the rod bolts to 70 ft/lbs.
Phil
Old Nov 8, 2005 | 11:19 AM
Brandon Boomhauer's Avatar
i've been waiting for results for a while... been following the build
hurry up already!
Old Nov 8, 2005 | 01:47 PM
7 Second Club
Pics will be up tonight...
Agenda:
install cam
install front and rear covers
install oil pan
100% finish the bottom end - clutch and bell housing
Torque heads down and start port matching intake
On the intake we're going to port match the intake to the heads and maybe use alittle epoxy.
Phil
Old Nov 8, 2005 | 02:02 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Um...yeah...we're gonna need some pictures...mmmkay?
Old Nov 8, 2005 | 05:06 PM
Beast96Z's Avatar
Originally Posted by bulletLS1
MINE TOO!!!!
Why so high (70)
It sounds like your going by the stock instructions. When using an aftermarket bolt, you need to use there instructions for TQ'ing. It's the bolt that is being TQ'd, not the connecting rod.
Old Nov 8, 2005 | 10:43 PM
7 Second Club
New Timing Chain
Old Nov 8, 2005 | 11:13 PM
ArcticZ28's Avatar
Thermal coated pistons
You consider coating the intake valves as well while you're at it?
Old Nov 8, 2005 | 11:15 PM
7 Second Club
If I had the money, the chambers, valves and exhaust runners would be coated also.
Phil
Old Nov 9, 2005 | 06:54 PM
67Ranger's Avatar
I like it... mine is coming along nicely too. I know you probably cant wait, just as much as me.
Old Nov 9, 2005 | 07:08 PM
7 Second Club
67Ranger,
What are you building?
Phil
