Help with cold start!
His car has no codes and the car is basically stock except for a lid and catback.
Any ideas?
Why would you think thermostat? do think if it were stuck open it would affect cold start?
It's a wierd problem because you would think if it was the IAC it would have a code.
I guess it could be the MAF but it would be hard to diagnose it.
It would suck if the problems is plugs or injectors because the car is an 02 with low miles.
I'm starting to think he might of got a tank of bad gas.
Like ls1greyhound said the car is basically stock with a lid and catback. The car started having a rough idle a few months ago and the fuel filter was replaced 5000 miles ago. I hooked a fuel pressure gauge to it yesterday and it read approx. 58 psi during the prime cycle however it is losing pressure, ie bad injectors or pump. During idle and while snapping the throttle the pressure gauge flutters ~5 psi. So I am leaning towards bad injectors but I am not sure if I want to drop $300 on a wild guess.
A few months back I got a P300 code after visiting the drag strip so I took it to the dealer and was told that my Pass. Side Cat failed. I am not sure if this is related but I think the problems I have now might have caused my cat to fail
I checked the IAC Motor the other day while installing my new lid (Ls1greyhound I broke down and bought the slp/blackwing lid used on the firehawks) and there isnt any carbon buildup. I try to clean the throttle body regularly 10000 miles or less.
I might go ahead and replace the plugs and wires for the hell of it and see what happens but I think it is fuel related.
Has anyone removed the fuel rails from the engine with the injectors still installed to check for leaky injectors?
Thanks for the input so far and keep it coming.
A melted cat can cause a rough idle and performance problems. Did you replace the cat when the dealer told you it was bad?
I think a set of headers and an offroad pipe should solve all your problems.
even if the TB is clean in front, in the back can be a pig... REMOVE THE TB, clean all from behind, leaving the little hole in the blade free.... check the TB-to-intake gasket....
after all is done.....
bent valve?????
bent valve?????
Maybe I should add that I have had a metallic noise coming from the front of the engine that I thought was piston slap. Sounds like a bucket of marbles and seems to be getting worse. As far as I know there are no exhaust leaks and I replace the Tensioner pulley a month or so back. Maybe I should pull the valve covers... But the noise shouldnt cause the hard start condition
I appreciate the help guys!
