Preliminary PRC Ported Dart Pics & Results!!-->
#41
Originally Posted by uberLS-1
Wow, you have a problem with my "Assumed" expertise, by what, doubting me with yours? tell me what I said is false, who cares? Prove it....
I have no problem with you presuming you are an expert.You can presume you are blue and from Mars for all I care. Again, I thought it was funny the way you went about it and your reasoning behind it.
#42
Originally Posted by xfactor_pitbulls
Agreed Bret. Thats why alot of the best guys test flow from 25-30". No matter what you do, an engine pulls more air than a flow bench anyway. Especially in the larger bore motors.
Brandon
Brandon
Turning up the bench is a really good thing that you can learn a lot from, no bench so far can pull as much as the motor sees yet.
Bret
#43
you know i started reading this post because of dart head info and pics, not to read your guys pissing contest. Keep you arguments somewhere else please and save it for people in another section.
#44
Location: Tinker till it blows, then back it off a notch, maybe!!
1 Post
#47
As far as Darts flow benchs go some of you may be interested in this link :
http://www.speedtalk.com/forum/viewt...431&highlight=
Reher-Morrisons' top cylinder head designer (Darin Morgan) has some personal experience/insights.
#48
1 Post
I've had good results with Dart products in the past
Just waiting....
#50
So, what is the price going to be with the "touch up" work? (ball park)
#51
Originally Posted by SStrokerAce
30" is a little light even..... Darts bench does 80" wet flow with fuel!
Bret
Bret
Brandon
#53
Probably wouldnt flow much more, he said initially they are setup for a 3.9 bore. Its not like a 2.1 valved head where you are shrouding the flow path big time. Nonetheless, sorry for hijacking your thread guys. Go get after that trickflow head and see what its got.
Brandon
Brandon
#54
#55
Sorry if my post annoyed anyone, wasn't my intent. I'm glad to see someone else's text book has the same info as mine! I thought mine was a big typo for a whil!
#56
Originally Posted by Jason 98 TA
We've been working on them a little bit more today Here's where they're at
.300 206
.400 259
.500 294
.600 320
.650 325
.300 206
.400 259
.500 294
.600 320
.650 325
Dart 225cc 2.055/1.600 x 11/32 valve
.200 144 112 78%
.300 204 151 74%
.400 260 193 74%
.450 282 ---
.500 297 214 72%
.550 307 ---
.600 312 225 72%
.650 316 ---
.700 320 232 72%
The customer wanted the ports to look "pretty" so they were just cartridge rolled and had some minor work around the guides to narrow them down, but the heads really liked this. So were looking at under 230cc intake port volume here. I have zero work in the bowls, nothing enlarged or dropped, I would expect some more flow above .500 with that, but that can be for another set. These castings make anyone look good on the bench, can't wait to get a set in the hands of someone really good.
The more impressive thing is that cranking up the bench to a lot higher depression doesn't bother these heads at all, they are happy as a clam with a smooth flow and NO turbulence at all. Try that on 95% of the LS heads out there and see what happens, most of them aint happy.
Bret
#57
1 Post
Dam close to the ones I checked in my shop today.....
Bret
Bret
Just wondering what kind of work you do...
#58
I don't port heads for a living, I'm just doing some testing for Dart on these castings. I do engines and valvetrains and I had a customer with one of my valvetrains want a set of these, so the stars aligned and everything worked out this way.
Bret
Bret
