HELP, installed heads and new cam, knocking like hell!!
Old Nov 18, 2005 | 09:20 AM
GuitsBoy's Avatar
Originally Posted by 777
Maybe something's wrong that has nothing to do with the cam. How's your oil pressure?
777 has a good point...
Did you give it about 5 minutes for the lifters to fully pump up, especially if you ve had themm out of the car?
Old Nov 18, 2005 | 09:28 AM
Orange Peel's Avatar
50psi idle, 70 wot, and I checked that right after the car started, it was idling at 50psi and stayed there, I let the car idle for a minute or so just to see if the oil wasn't getting to the lifters enough, etc. It's pissing me off that the car idles perfect, nothing seems wrong but the loud *** knocking
Old Nov 18, 2005 | 09:33 AM
PREDATOR-Z's Avatar
I have PRC stage 2.5 (2.04/1.575)
And upon inquiry I was told by TSP that their 233/239 would be tight and that the 232/234 was about as big as I should go with .054 gaskets.
So, I too suspect PTV contact.
Old Nov 18, 2005 | 09:51 AM
I installed BRAND new Comp 850 lifters, the OE replacements, I let the car idle for a minute or two, and did this a couple times, same loud noise there
Old Nov 18, 2005 | 09:52 AM
But if it were hitting and I bent the valves, the car should technically not idle right or run right anymore, it should stumble, backfire, stall, etc. correct?
Old Nov 18, 2005 | 09:57 AM
RPO_Z06's Avatar
Did you pre-soak the lifters ?
Old Nov 18, 2005 | 09:58 AM
SS1875's Avatar
Mine tick loudly( dont knock), sounds a little more like PTV, but do agree that it should stumble/stop running if the valves were the culprit.
Old Nov 18, 2005 | 10:01 AM
777's Avatar
777
Old Nov 18, 2005 | 10:35 AM
Lifters were lubed fine, not the problem.
Old Nov 18, 2005 | 10:39 AM
PREDATOR-Z's Avatar
Maybe your p-rods are still too short?
Did you do a wipe test?
What is your preload value?
Is the noise comming from top or bottom? (I remember your running G5X3/G5X4), I know you said intake area but are you sure?
Old Nov 18, 2005 | 10:45 AM
oange ss's Avatar
they told me their Torquer 2 would clear no problem, what the hell ?
Old Nov 18, 2005 | 10:47 AM
  #32
PREDATOR-Z's Avatar
Both are torquer cams, I didn't say it wouldn't fit, I said it will be tight on the 233/239 and comfy on the 232/234
Old Nov 18, 2005 | 10:53 AM
  #33
Ed Curtis's Avatar
Cool
We're working on this...
Doing a leakdown test first...
1) The gross lift has NOTHING to do with P/V clearance. Forget the .630" lift will ya.
2) The IO/EC are identical to an X2 at a 109* ICL and I was told this cam clears the 5.3 heads. Even the X3 is tight but may clear and that one is much bigger than this stick.
3) Still not sure if the cam is in correctly but this will be checked. Accumulated tolerance on the keyways and sprockets may be an issue but no way to tell where this is until later tonight. Like "Pred" said, dot to dot isn't the best way to do this but Scott will be verifying a lot of this stuff this weekend.
4) Soaking the lifters does nothing to them other than lubricating the outside. Not a bad idea but this has no effect on the internals or the pumping up of said lifters. The oil pump feeds the internals and unless these new lifters are defective, they should be fine. Again, one more thing to check and inspect.
Stupid as it sounds but it's actually too bad the car runs so well because the troubleshooting of the noise is frustrating. No backfiring, no huffing out the TB or anything out of the ordinary powerwise. We're hoping is not something foreign that got into the cylinder (Scott is VERY fussy) or something more fatal like a rod bearing. (That was another item suggested by Scott's friend.)
We're working on this people....
Question for Pred.....
The TSP cam you mentioned. What LSA and ICL? Without that info, the 233-239 duration numbers are meaningless to verify any P/V clearance comparisons. You can Email or PM to not hijack the thread.
Ed
Old Nov 18, 2005 | 11:01 AM
  #34
Thanks for chiming in Ed You have been MORE than helpful throughout this entire process and I thank you!!
I don't know about the pushrods being too short or too long, I did the preload per Ed's instructions the best I could/know. The first time with the 7.35's it seemed to short, I installed the 7.4's and they seem to be correct if not a smidge too long. But the outcome of both pushrods is identical, the knock is there. I think the car ran a little better with the 7.35's to tell you the truth, but both times idling and revving it was amazing how smooth and quick the throttle response was, I mean, I BARELY touched the throttle body and it revved fast.
It could be a stupid install error and something fell in the cylinder during install, I vaccumed the hell out of it, wiped the walls down, but maybe when the head was going on something fell in, who knows. I will do what Ed says for checking, worst case, the heads come off and I see what happened, if nothing is apparently wrong, it could be the motor just let go at the worst possible time I really don't feel like installing the stock heads and seeing if the noise is still there, but that may be my EXTREMELY last resort.
Old Nov 18, 2005 | 11:50 AM
  #35
vettenuts's Avatar
Do you have access to a boroscope? That would be helpful in examining the valves, cylinders, etc. without disassembly as a starting point.
Old Nov 18, 2005 | 11:52 AM
  #36
PREDATOR-Z's Avatar
Good point.
BTW, I don't want to scare you, but I did fish a loose retainer out of the water passages from my PRC's when I got them (but that was an early version worked at Racetech)
Old Nov 18, 2005 | 11:59 AM
  #37
Nope, don't have access to one of those
Old Nov 18, 2005 | 12:02 PM
  #38
Good point.
Oh, I have read stories of crap in the heads, so I took my air compressor and cranked it to 80psi and blew threw the heads for a while, just to make sure nothing fell out, etc. I looked them over well too, but who knows
Old Nov 18, 2005 | 12:07 PM
  #39
777's Avatar
777
I would have said something about a bearing as well, but your oil pressure is good so I doubt that's the case.
Old Nov 18, 2005 | 12:09 PM
  #40
I pray you are correct
