HELP, installed heads and new cam, knocking like hell!!
Old Nov 18, 2005 | 12:29 PM
  #41
DanZ28's Avatar
When I put new lifters in, they made alot of noise for a while, sounded like loud banging as well. It took several minutes for it to go away but it finally went quite. You think this could be your issue, lifters just not pumped up yet?
Dan
Old Nov 18, 2005 | 12:48 PM
  #42
oange ss's Avatar
Originally Posted by vettenuts
Do you have access to a boroscope? That would be helpful in examining the valves, cylinders, etc. without disassembly as a starting point.
i doubt most people on this board even know what that is
Old Nov 18, 2005 | 01:08 PM
  #43
Orange Peel's Avatar
Dan
I don't know if it's that, I will check to see if the valves are bent, if they aren't and it's good, I may try to let it idle longer before tearing it down. It should have had plenty of time to get them pumped up, I held the revs at 2000rpm area for a little bit to get the oil pumping faster, and it didn't make it any less loud, same loudness.
Old Nov 18, 2005 | 02:35 PM
  #44
vettenuts's Avatar
I have one I use on the motor, but then again, if you are my age you sure know what it is
Old Nov 18, 2005 | 06:21 PM
  #45
INTENESS's Avatar
If you decide to start the car again youi ight want to pick up a stethscope at autoparts store to see were the knocking nosie is coming from.
Old Nov 18, 2005 | 06:24 PM
  #46
I think it's gonna be hard to find, it seems to be all over, and it would make me deaf It's noisey
Old Nov 18, 2005 | 06:50 PM
  #47
oange ss's Avatar
you can also use a screwdriver, put the handle to your ear and the tip on the area of your motor you think the noise is coming from, obviously you'll need a long handled one for areas of the block and watch the belts
Old Nov 18, 2005 | 07:29 PM
  #48
Mr. Luos's Avatar
Tune?
Old Nov 18, 2005 | 07:50 PM
  #49
GuitsBoy's Avatar
Originally Posted by Mr. Luos
Tune?
That'd be rough if he's pinging at idle!
Old Nov 18, 2005 | 08:11 PM
  #50
No bent valves, pumped air into the cylinders, sealed shut, just a faint sound of air that is normal. I tapped on the valves and they made a pop, and shut like they are supposed to be.
Ed said to reset the rockers and run it longer, maybe air in the lifters or something.
Good news I must have installed the heads and cam right, so we can eliminate PTV issues Yipee!
If it still knocks after a few mins, I will drain the oil and look for metal, if it's there, rod bearing went and at a VERY bad time!
Old Nov 18, 2005 | 08:48 PM
  #51
steveb's Avatar
Did it get any louder when you where reving. Thanks Steve
Old Nov 18, 2005 | 09:30 PM
  #52
SLowETz's Avatar
How long did the motor sit after pulling the heads? The reason I ask is that I've seen cam lobes become pitted after being soaked by coolent from the head removal when the motor sat for a long period of time. Possible the coolent galled the main/rod bearings?
Did you change the oil before the initial start up?
How long did you run the motor after the installs before you shut it down?
FWIW.... I've had motors after a H/C swap w/new lifters sit there and make all kinds of racket for several minutes even after oil pressure came up.
When you said it runs smooth and revs fast.... no irratic behavier.... I'm leaning toward it just didn't run long enough to pump up the lifters completely/bleed all the air out of the system.
Good luck-
Old Nov 18, 2005 | 11:26 PM
  #53
Mr. Luos's Avatar
Agreed.
I had it happen to me though. Some nasty knocking. Seems it was bad gas mixed with the stock tune.
Old Nov 19, 2005 | 12:05 AM
  #54
Well I readjusted the rockers, set the preload with the 7.35 pushrods, started it up, let it idle for some time, and had a couple local car guy friends here, and it's not knock anymore, it's VERY excessive valvetrain noise, like a MILLION sewing machines. I left Ed a message to see what he thinks, the preload I thought was about right, but not sure if the comp 850 lifters are THAT noisey or what. I took the car for a little spin around the block, kept the rpms under 2500, and the noise gets louder with RPM, definitely valvetrain, you can hear it if you put your ear next to the valve cover. But the car runs FLAWLESSLY, no bucking, no stumbling, better than it did with my X4 and stock heads, just butter and this is without a retune yet.
So, now it's time to track down the valvetrain noise, not sure if the pushrod length is wrong or what. I will see what Ed says.
It didn't get up to full operating temps, maybe coolant temps of 130 or so, didn't want to run it too long if something is up. The pistons definitely didn't hit the valves as none where bent.
Good news so far, I just can't live with that much valvetrain noise. I will get a video of it tomorrow and post so you can hear what I got
But for now, I am much relieved that it's not a spun rod bearing. I will change the oil tomorrow and see what's in there. I didn't change it before start up as I was planning to afterwards once the crap got out of the top end.
I wonder if my lifters are bad? They are brand new but who knows...
Old Nov 19, 2005 | 01:33 AM
  #55
eallanboggs's Avatar
You said KNOCK, but the sound you hear when you first start the engine after top end work is more like the sewing machine that needs oil sound. You even see TV commercials these days showing people making funny noises with their mouths while trying to mimic the sound their car makes when it malfunctions. We wouldn't laugh if it weren't true. KNOCK is more like one moveable object hitting another non-movable object. KNOCK is much worse than tick. If you actually had KNOCK which resulted in 8 bent intake valve stems you wouldn't continue to idle properly and rev quickly. I know it hurts to stand there and listen to your motor make all those horrible sounds when you first start it after having spend a lot of time and money to fix it up, but you have to learn to bite your lip or grit you theeth for those few minutes that seem to last an eternity until she quiets down.
Old Nov 19, 2005 | 10:08 AM
  #56
dudas35's Avatar
I am glad the knock is gone, with that much lift it is going to sound like a large sewing machine. I would never thought that cam on those heads would clear stock pistons, but we can all be wrong sometimes. G/L
Old Nov 19, 2005 | 10:45 AM
  #57
I think the preload is wrong with the 7.35 pushrods, I will be swapping out to the 7.4's today and relistening. I expect some noise as I had it with my X4, but this is like 100x's more than it should be And as for the cam, it's a lot to do with the valve events, etc. It's not an off the shelf cam, I had Ed make it to my exact mods and car, so far it's perfect!
Old Nov 19, 2005 | 11:01 AM
  #58
SLowETz's Avatar
JMO.... but I ALWAYS change the oil before initial start up w/some cheap dyno oil. Too much garbage in the oil pan after a head swap. You'll be suprised how bad the oil looks when you pull the plug....I'll let it run until it reaches operating temps and make sure everything is propper, then change it again w/the good stuff..... but that's just me.
Old Nov 19, 2005 | 12:41 PM
  #59
777's Avatar
777
My oil was clean as a whistly I'd definatly check those p-rods, I don't see why you would need the 7.35's anyhow. The heads aren't milled. You should do a whipe test to find the length you need.
Old Nov 19, 2005 | 12:57 PM
  #60
I plan to change the oil before I redo the pushrods today. The heads aren't milled but I'm using a thinner gasket. The heads were deck cleaned, probably not that much taken off. Just figured I would have both sets in case one wasn't right.
