HELP, installed heads and new cam, knocking like hell!!
Here's a list of what the car has on it now....
PRC Stage 3 5.3l heads with 2.055/1.60 valves, not milled, just a deck clean
Cometic .040 gaskets
Comp OE 850 lifters
7.35 pushrods/7.4 pushrods in now
Custom Ed Curtis cam 236/240 .630/.608 on 113lsa (he said it would clear without flycutting, I told him what I had and wanted)
LS6 intake
QTP 1 7/8's headers
ANY idea what I should try next, I don't feel like taking the heads off, I don't think it's hitting (PTV), when I took the 7.35 pushrods out none were bent or anything.
It's just weird how it idles great and revs FAST! Just SOOOOO ******* loud!!! Please help!
Peace,
Adrian
Comp OE 850 lifters
LS6 intake
QTP 1 7/8's headers
The pushrods are not bent cause they are hardened pushrods. they are harder than the valves, so the valves are the ones that are bent.
If so... somthin's up.
Everytime I've done a cam swap I'll get the lifter/valve noise until it builds full oil pressure that's loud and "can" sound like knock(even when spinning the motor w/out fuel/spark to build pressure). How long did you run the motor?
Agree w/the above posts..... unless you got a much smaller cam than ordered....or the flycut fairy made a visit you've got some trashed parts in your motor.
Pull a head and have a look.....
Sorry, but what can I say, it is not ED's fault.
Goodluck!
I will pull a head and see what it looks like, definitely sucks. He said he has done a bigger cam than this and it cleared fine.
And I'm POSITIVE it idles PERFECT and reved EXCELLENT, just makes noise, it didn't stall, backfire, stumble, NOTHING, even on decel off the rev, just knocks.
