did cam swap tonight have questions
i did a cam swap on a 98 ls1 after work today put new oil pump timing chain and put a 160 thermostat in it but when i let it sit there and run it climbed almost 3/4 the way on the guage after about 15minutes of running is there something special i have to do to get the air out of the radiator?
did u double check to see if ur fans are coming on?/plugged in.try running it with out the cap on till it either comes up to temp. or starts puking out the filler neck then put the cap on
i usually loosen the front coolant line on the driver side to let the air come out from there. Took about 10-15 minutes for my car to get rid of almost all the air after my head/cam swap..
Put it over your shoulder,give it a couple of whacks and make it beltch!! On a more serious note...try tapping lightly on the Thermostat housing to make sure the stat isnt stuck, also make sure the upper radiator hose is getting warm to the touch...if so the water pump is working o.k. after that make sure your radiator cap is sealing properly as not to let air in.
FWIW, when I changed my water pump, I unhooked the small coolant line on the driver side of the tb. With the cap off and car running, I filled as necessary until fluid came out of that small line. I figured this would be the best way to get rid of air since it is the highest point of the cooling system.
p.s. this also worked on my friends car after a cam swap.
