Adjustable cam gear sprocket?
Old Dec 31, 2006 | 06:54 AM
The stunningman's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/608336-bushing-instead-adj-t-chain-also-question-cam-experts.html
Old Dec 31, 2006 | 04:33 PM
98Z28CobraKiller's Avatar
Restricted User
I would do that but I dont want to get into degreeing the cam. I just want to turn it to the correct line and be done.
Old Dec 31, 2006 | 07:09 PM
gollum's Avatar
Originally Posted by Patrick G
If no one makes one, I can always do what we did in the old days and use an offset bushing kit. Yes, I know, it's old school, but it's worked for years.
I used the offset bushing kit. Its very simple to install if you have access to a drill press and the correct size drill bit. Be carefull not to drill completely through top cam sprocket.
If you discover that your 224 cam is dead on are you wanting to retard or advance the cam?
Old Jan 1, 2007 | 11:58 AM
Restricted User
Read ahead and you will see that he ended up not doing it that way. He used the cloyes adjustable cam sprocket.
Old Jan 1, 2007 | 12:16 PM
Patrick G's Avatar
LS1 Tech Administrator
Keith, I got the Cloyes adjustable top sprocket 3 cams ago. I used it to dial in my TRak cam, my AFR 234/238 114 cam and my current 223/227 110LSA cam. Interestingly, I had to back the cam up -2 degrees for it to be in at 110ICL. Had I just lined up the dots, the cam would have been installed at 108...which was not where I needed it.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jan 1, 2007 | 10:10 PM
Chris81's Avatar
I found this set i'm going to use with my setup.
http://www.sdpc2000.com/catalog/4288...Chain-Sets.htm
Old Jan 2, 2007 | 09:04 AM
Restricted User
Damn, that is the cheapest adjustable set that I have seen. Unfortunately it looks like the only way to move the cam timing is by using the crank sprocket. Doesn't look like the cam sprocket has any adjustment to it. I am going to measure the depth and diameter and anything else that I can measure in order to see if I can avoid pulling my oil pump out. I will advise.
Old Jan 2, 2007 | 12:06 PM
bigdsz's Avatar
I don't understand why you guys don't check out the infinitely adjustable Comp set. It is adjustable from the cam sprocket to however many degrees you want. A few years ago I only paid $100+. A friend of mine who is a master GM tech was very impressed with it. He bought a Cloyes earlier and thought he got fkd.
Old Jan 2, 2007 | 03:21 PM
Restricted User
2 reasons.
1) I belive that the Comp set is double roller and therefore there is no chance of compatibility to my crank sprocket.
2) I dont believe that it is marked for the timing degree adjustment therefore requiring you to have degree the cam with a degree wheel (which I dont want to get into).
Please correct me if I am wrong.
Old Jan 2, 2007 | 04:51 PM
bigdsz's Avatar
It is positively single roller and it also shows dot to dot. From there you can fine tune as you want, advance or retard. It is not necessary to degree but advisable. Call Comp or any sponsor that carries Comp cams, it's really a no brainer.
Old Jan 3, 2007 | 09:14 AM
Restricted User
Well the Cloyes Hexajust just arrived. I will take pictures and have more info later.
