Took the plunge, TORQUER 2
Well,
I just ordered the Torquer 2 (232/234, 113 lsa+1)
For the Z.
As much as I love the Stealth 2, I need something with more power above 5K rpm for the track.
Setup will be:
FIPK
Stock MAF (ported ends)
80mm BBK (ported and polished by myself)
Modified LS6 intake
PRC stage 2.5, 5.3L (2.04/1.585), milled .010
GM .054 graphite gasket
Comp 850-16 lifters
J-WISS single chain
Stock rockers
Stock oil pump
MAC mids (primary and collector mod)
G2 ORY (modified to fit MACs)
3" piping into Magnaflow muff
FLP stage 4 A4
VIG 3200
TCI plate
3.73 10 bolt with TA girdle
Spohn TQ arm with 2 loops
BMR relocation brackets
Poly bushings (motor mounts, trans mount, sway bar (rear- front is off)
And of course a 5177 dry NOS (modified dual stage)
Some other stuff I can't think of....
Need to go mid to low 10's
on juice.
Should be in within a week.
BTW, I was making 429 rwhp with the Stealth 2 on a 93 Octane tune (running 98 actually). TC locked.
I'm hoping for an additional 20rwhp, but really want more pull after 5K
The Stealth days of the Z are over
For the Z.
Setup will be:
FIPK
Modified LS6 intake
Comp 850-16 lifters
J-WISS single chain
Stock rockers
Stock oil pump
FLP stage 4 A4
VIG 3200
TCI plate
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Cool, can't wait to see what it puts down and runs at the track. What's the elevation over there??
You will enjoy the lope with the new cam, and you are going to be getting all kinds of attention with it too, I get people all the time asking what it has, etc, "sounds mean as hell dude!", etc, etc
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I am running the TSP Torquer 1 cam (233\233 .595\.595 on a 112 LSA) and I really like it..from 4000 RPM on it pulls very very strong up to 6800 and doesn't act like it has run out of breath at that RPM..but on stock rod bolts I shift at 6500..the car has a great lope at idle and makes a bunch of power over 5000 RPM..It makes the numbers in my sig through the muffler on stock heads..getting ready to put a set of heads on it and it sould really pull much stronger then..you are going like it with the set up that you have..good luck with it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by slt200mph
I am running the TSP Torquer 1 cam (233\233 .595\.595 on a 112 LSA) and I really like it..from 4000 RPM on it pulls very very strong up to 6800 and doesn't act like it has run out of breath at that RPM..but on stock rod bolts I shift at 6500..the car has a great lope at idle and makes a bunch of power over 5000 RPM..It makes the numbers in my sig through the muffler on stock heads..getting ready to put a set of heads on it and it sould really pull much stronger then..you are going like it with the set up that you have..good luck with it. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I know you didn't ask me, but IMO, the low end was not affected at all from stock (I'm an A4 though with a 3500 stall so I'm used to sluggish). I personally didn't get much time with the cam since I killed my trans 3 hours after it was installed, but I can't wait to get back on the road with it. But it pulls HARD.
Restricted User
Pred...your going to love the Trqr2. I installed one on my buddies 02SS and the tuning was relatively quick, no longer then install time. It seems to react well without the split duration reversion of some smaller cams. Basically I did the VE reduction on lower rpm region, added timing at idle, flipped the TB Screw and cranked it out a little. Changed the AFR from stock rich to a little leaner at the WOT airflow as well. This cam sounds nice as hell at idle, and runs very well, even with a lil 3000 stall w/stock 3.23 gears.
FWIW, I posted the tune in Horists .bin repository, feel free to check it out.
GL and enjoy.
Charlie
GL and enjoy.
Charlie
GL and enjoy.
Charlie
GL and enjoy.
Charlie
Nevermind, I found it, not even Google would come up with it though. http://www.horist.com/hptuner/
Dan
Dan
Thanks guys, I'm a little excited. Reason I chose that one is that it fits the PRC heads pretty well. Chose 113 +1 instead of 112 +2 for a little more idle vacuum since I have a modulated tranny..
it is 232/234, .595/.598 113 lsa+1
My tune is done with the help of Allen Nelson as I'm no genious in that section (learning slowly but surely). He is a heck of a guy to deal with.
Eventually i will need to get a 9" rear so I can run a bigger stall. I'm ammazed the 10 bolt is holding that well so far.
But we all know $$$ are not that easy to come by.
What will be nice to see is the differences between a good small Stealth and one bigger cam (similar to FM13 etc..).
LS1 Tech Administrator
Once you get it tuned in, I think you're going to wish you had gone bigger. You're going to like the additional pull up high though.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by krexken
Stock short block? Curious why you'd use that thick head gasket also?
When I got the heads (PRC 2.5) they were unmilled so I can run .045 Cometic.
But a nasty gash between water passage and bolt hole require .010 mill.
Knowing I will step up in cams soon and I do not want to flycut (and I like comfy PTV clearances ~ .08 int and .10 exht, I had to use the graphite (which was in hand at the time)
I live overseas so quick parts availability is nonexistant.
I do run Kateck rod bolts BTW. So far so good.
