G5X2 H/C on A4 car?
Adam
Adam
with the right tire and that cam your in the 11's N/A for sure.
then I get the OH **** look. Trending Topics
then I get the OH **** look.I'm still looking at heads...I just don't want to spend the bank for AFR's as much as I want them.
I love the G5X3 on 114.
AFR's are next on my list.
John
John
I asked Tony Mamo and Louis at LG which heads would be better suited for my stock cube motoer and G5X4 cam and both sayed the 205's, with a good amount of milling on them to bump up the compression.
you gonna do the install your self?
Just be sure to check PTV, and when that time comes I will help you make sure it is all good to go if you are unsure what will fit/wont fit/needs flycutting.
My preference is the AFR 205s, but stock castings ported by a reputable porter can go a long way as well.
We are doing extensive head testing with ET, RHS, DART and a few others. I hope to report on those sometime after the new year
Louis
What size stall you got to match the cam?
Glad to hear you will be doing the swap yourself as it will save you a lot of money.
