taking heads off need help!
Old Dec 3, 2005 | 10:11 PM
  #41
SELLSZ06's Avatar
took the d.s head off with the p.steering assembly after taking pulley off, need to drain coolant from the plug, not the lower radiator hose. need to fix a scratch on the head. Right now Iam clean the holes, fun stuff.
Old Dec 4, 2005 | 05:56 PM
  #42
Black Z/28's Avatar
SELLSZ06, I've been reading your post because I'm also removing my heads this weekend. I know this doesn't help you now but I figured I'd post my experience with the power steering pump.
First, I did pull both radiator hoses (at the radiator) and let the water pump just sit there with the other hoses still connected. Next, I removed the top ps pump bolt (obviously easy). Next, I did the bottom bolt. I don't know if anyone has tried this but a stubby wrench and socket does fit in there. This bolt was no problem at all, especially with the water pump out of the way. I probably could have done it with the water pump in place but it definitely would have been harder (shorter turns):
The bolt on the back side would normally be the toughest, but with the other 2 bolts removed this one was very easy as well (even easier because I fabbed up a skinny wrench to do the job). I did break the bolt loose with a 'real' wrench first:
Water pump and ps pump just hanging:
The tools that I used (plus a normal 15mm wrench):
Other than the time it took me to fab up the skinny wrench, this procedure was pretty damn quick. I also expect the re-install to go pretty easy as well.
Maybe this will help someone else.
Old Dec 5, 2005 | 05:09 AM
  #43
JL ws-6's Avatar
Race your car!
I just swapped the heads on my car this weekend... with some help from the guys at eastside, and noyzee... here's what I can say:
Water pump stays on.
Power steering pump comes off easy, if you pull the pulley, which is also not too hard, if you have the puller/reinstall tool.
The fuel line comes of with a pair of pliers, pull the clip off, and slide the rubber piece back onto the fuel rail, that's how we did mine.
No need to really drain the block. Might make less of a mess.. but with the mess I already had, there' was no point.
Headers suck to remove, but suck to reinstall even more.
The back manafold bolts on a f body are a pain to get to.
The edge of the heads are VERY sharp.. one of my knuckles will never be the same LOL.
The bolts on the back of the heads, with the grounds on them, are a pain. All my grounds on the drivers side all went back on with one bolt rather then the 2 thank you very much.
Heater box on an f body is in the way of a big tq wrench.. hole now in the heater box cover on passengers side thank you. ( no air sees that part, should still be fine.. gonan come out eventually anyway, and can not be seen with car back together )
Did I mention the edge of the heads are sharp?
Old Dec 6, 2005 | 02:15 AM
  #44
SteelBallz's Avatar
good info...
Old Dec 6, 2005 | 11:51 AM
  #45
SELLSZ06's Avatar
BLACKZ28 thanks anyway, i like that wrench you made good idea. I could fit a wrench in there to break that bolt so I just took the p.s. assembly out on the head after removing the pulley.
Jl Ill be putting the heads on today and Iam looking forward for those bolts in the back of the heads. p.s Ill let you know what my knuckles end up like.
Old Dec 6, 2005 | 12:30 PM
  #46
slt200mph's Avatar
Good luck on your assembly process..
Old Dec 8, 2005 | 11:53 AM
  #47
JL ws-6's Avatar
Race your car!
how did the whole assembly go? get teh car fired back up yet?
Old Dec 8, 2005 | 10:02 PM
  #48
SELLSZ06's Avatar
yes everything is back on, Iam rebuilding the whole set up, changing ls1 to ls6 pcv, and adding the studs. ARP sent me only 8 out of the 10 I should get them tomorrow. And the turbo is getting new seals Ill get that back in a week. I might start the car tomorrow w/o the turbo being on just to make sure I didnt **** anything up. Iam a little scared being my first time , hope its fine.
Old Dec 9, 2005 | 04:44 AM
  #49
JL ws-6's Avatar
Race your car!
Turbo... didn't know you were on a turbo setup. What kind of car? I should have swapped my pcv when I had mine apart, I tthought about it.... but figured why bother, I have a amw catch can on, it's doing it's job, the intake didn't have much in the way if oil in it, so I said to hell with it.
Old Dec 9, 2005 | 05:34 PM
  #50
SELLSZ06's Avatar
its a 02 SS with a gt42 phamspeed, but Iam waiting for my Hi-Flo kit to come in. I too have aAMW can.
Old Dec 9, 2005 | 05:56 PM
  #51
JL ws-6's Avatar
Race your car!
Were you able to get the plugs in with your phamspeed kit? I hear that there's no possible way to do it......
Old Dec 10, 2005 | 12:57 AM
  #52
SELLSZ06's Avatar
yes never had to change them, but I think I could. Iam selling the manifolds as soon as my Hi Flo comes in this month.
Old Dec 11, 2005 | 07:54 PM
  #53
CamTom12's Avatar
JL, you bought Brad's heads?
I'm throwing a set of heads on myself...
Old Dec 12, 2005 | 04:21 AM
  #54
JL ws-6's Avatar
Race your car!
Bought, installed with his help. Definately made a big differnece, we didn't dyno, not much point in retuning in 20 degree weather. Will take care of that in the spring, car's just gonna sit between now and then anyway.
Gary's Th400 is going in next.
