Changing Pushrods
Old Dec 18, 2005 | 12:31 PM
PREDATOR-Z's Avatar
Originally Posted by vettenuts
Start with engine at TDC on #1 and then do those valves on the base circle. LS1howto has the sequence. Then rotate 360 and do the rest, then 360 and check first set, then 360 and check 2nd set. Don't try and compress the springs with the bolt. This is per the service manual on my Vette. I would also soak the PR's in oil so they fill (they will bubble) and maybe use a dab of Redline assembly lube where they go in the rocker for the startup.
It is TDC 1 and 6, rotate only 90* then follow sequence untill you finish at 360.
Sequence is 1 & 6, rotate 90, 8 & 5, rotate 90, 7 & 4, rotate 90, 3 & 2. END
Old Dec 19, 2005 | 09:11 AM
BoneSS's Avatar
Thanks!
Old Dec 19, 2005 | 07:38 PM
Dipstick's Avatar
When I put my LS6 cam in, I tightened them all to 22ft/lb, rotated it and it made no difference. None of the bolts moved from the previous position.
Old Dec 20, 2005 | 08:06 AM
BoneSS's Avatar
Is that generally the way it is guys? They do not move?
Old Dec 23, 2005 | 07:53 AM
BoneSS's Avatar
The rest of the car has been apart also, so I believe I have rechecked all the other work. It was by a speedshop on the board, but I will keep the name private.
Old Dec 23, 2005 | 08:31 AM
dudas35's Avatar
I have noticed the same thing on 2 cam installs, seems the springs being compressed have little to do with the torque value on the rocker bolt. Never hurts to make sure though.
Old Dec 23, 2005 | 01:32 PM
vettenuts's Avatar
You will reach the torque value with the springs being compressed, but not necessarily the required bolt pre-tension between the mating surfaces.
