Will it go 650 RWHP N/A
Harrop butterfly intake
http://www.harrop.com.au/products/intake_systems.html
LS7 heads or ET Performance 265/41 heads (both are equal really, the 265's are a little better)
248/252 .610/.610 113 lsa (upgraded from my 242/242 .610/.610 114 lsa)
Its 480 RWHP 483 RWTQ now.
The reason I ask is because there's alot of talk that the 450 RWHP LS7 engine should make 600-650 RWHP with just a cam swap and an exhaust. Therefor, there is no reason my 436 wouldn't do the same or better.
Are you looking to pickup 170RWHP with a better set of heads, bigger cam and intake swap?I noticed you have an A4... I don't think 650RWHP will be possible with an hydraulic cam and 436CI... if you could hit 600RWHP I think that would be major accomplishment!
When is the swap going to happen? I am very curious to hear the results...
I'm unsure whether I want to go for all the N/A power possible (hydraulic cammed and pump gas) and than spray a 250 shot.
OR
Just get the Hi-Flo 76GTS single turbo kit and call it a done deal. This seem's like the better way to go for the power I'm wanting/needing. Plus I won't have to buy new heads and intake. It'll actually be cheaper than the N/A route. Either way the engine needs to be torn down.
But I do like the raw power of my N/A engine.
Still trying to make up my mind what to do, but one of these will begin sometime in January.
Q
And why does a solid roller make more power than a hyd?
P.S. Stay n/a, there are plenty of turbo cars running around, not many north of 600+rwhp n/a cars running around
. Plus, you can always add that additoinal 150-200 shot down the road. Which 265 head....40 or 41?
More info about these "600rwhp" cars would be appreciated!
If so you are going to need a T-88 at least.... you will have to get the flow of that motor and match it to the compressor map of the turbo and see where u will be.
Plus new Pistons.... and a fuel system from hell to power it..... **** i have over $3000 in my fuel system. What do you have fuel system wise now??
Kyle
I'll be doing a drag setup with some ET or DART heads and big cubes with an M6. I'm sure we'll see plenty of numbers this spring. my goal is to be done by March 11th.
