Will it go 650 RWHP N/A
Originally Posted by V8er
I am sure the Harrop is a great unit but your post is a little confusing. Are you sure these "600rwhp" cars have the Harrop with stock LS1 TBs
More info about these "600rwhp" cars would be appreciated!
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Oops, my bad. They do not have TB's , as the Harrop intakes don't use them or MAF's. Speed density tuned.
But yes, they have LS6 heads and intakes with smaller cams than mine (which mine is a 242/242 .610/.610 114 lsa) and 427ci. Very tame cars for daily drivers.
E-mail or call Ken at Harrop, he'll tell you about there 600+ RWHP daily drivers.
Originally Posted by NA$TY-TA
FYI a 432ci motor is to much motor for a T76GTS.... you are going to be out of the turbo's efficiency way early... No reason to spent that much $$ if you are only wanting 650rwhp or are you wanting 650+250?? 900rwhp??
If so you are going to need a T-88 at least.... you will have to get the flow of that motor and match it to the compressor map of the turbo and see where u will be.
Plus new Pistons.... and a fuel system from hell to power it..... **** i have over $3000 in my fuel system. What do you have fuel system wise now??
Kyle
Kyle
OR
HI-Flo single turbo kit with my current LS6 intake, ported LS1 heads and get a larger TB, mine is stock ported still, I know, WHY do I still have a stock TB with a 436 stroker?
So, what single turbo will feed a 436 properly?
yes they do, they have 8 individual TB's. one for each intake runner. they are around 55mm I think. they are SD tuned though. no MAF
Its a 436. I was either going to go for as much RWHP as possible N/A (hyd cam) and than spray it with a 250-300 progressively controlled shot.
OR
OR
https://ls1tech.com/forums/dynamometer-results-comparisons/410979-fms-408-stroker-gt55-turbo.html
Now that is a 408 with a GT55 wich is a 91mm turbo......
this is on 12.5 lbs of boost, 16 deg's of timing
![](https://img375.imageshack.us/img375/2575/skora125lbs9br.jpg)
All it takes is $$$$$
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Kyle
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
https://ls1tech.com/forums/showthread.php?t=410979
Kyle
Kyle
So what turbo will fit into the Hi-Flo single turbo kit (installed where the battery is) that will accomodate my 436 properly.
I want over 1,000 RWHP. 844/829 just isn't enough.
6 Second Club Moderator
My 436 with:
Harrop butterfly intake
http://www.harrop.com.au/products/intake_systems.html
LS7 heads or ET Performance 265/41 heads (both are equal really, the 265's are a little better)
248/252 .610/.610 113 lsa (upgraded from my 242/242 .610/.610 114 lsa)
Its 480 RWHP 483 RWTQ now.
The reason I ask is because there's alot of talk that the 450 RWHP LS7 engine should make 600-650 RWHP with just a cam swap and an exhaust. Therefor, there is no reason my 436 wouldn't do the same or better.
Originally Posted by LASTLS1
No way that will happen with that small of a cam!!! You will need alot of compression and ALOT of rpm. Good luck.
Running full-time on 104 octane is not a problem either.
With the heads and intake you're talking about I wouldn't worry about a HUGE cam so to speak, but would try to keep your compression up if you will be running around on 104 all the time. For comparison sakes the comp cams sb2 headed camaro produced 675 hp with 414 inches, 10.5 to 1 compression w/ pump gas, a 230/236 112 lsa cam which was solid but only has .600 or less lift, a single plain sb2 manifold (which the Harrop is superior too), 1100 cfm 4150 throttle body, and a few other goodies. This motor made peak torque at 6000rpm and peak hp at 6800rpm. The sb2 heads are probably the equivalent of the bigger et offerings and may fall a little behind the new canted valve head. Point to all of this is that if you are going to be running these killer heads with a REAL (not lsx style) intake manifold things change drastically with what you need to make the power.
I'm shooting for some big big power in my pump gas 434 c5-r headed street/strip motor (actually similar to what you're trying for, not quite as much though cause i'm going through a th400) and my cam is much smaller then most would think on this board. Good luck
Originally Posted by vmax1500
I wonder how the LS7 intake will work... I hear it's supposed to flow much better than a Fast 90 LSX...
#32
Considering the kind of numbers LS7 Z06's are putting down, I am very very curious to see how an aftermarket LS7 head like ET's would work with the same displacement along with a very agressive cam and stock LS7 intake... It seems like the average bone stock Z06 makes 450RWHP and I read about an HPE car that just made 505RWHP with a small cam and long tube headers and no tuning... Is 600RWHP possible in more of a race configuration, IE no accessories aside from alternator and off road pipes... This would be a pretty sick pump gas hydraulic cam motor... stock Z06's have trapped as high as 127MPH... an extra 150RWHP would be good for close to 140MPH in the 1/4!!!
#33
As much as 750rwhp has been achieved in a n/a 427 with ls6 heads with 14/15 to 1ish compression and a max effort solid roller/sheetmetal setup some time ago. I don't see any reason why 600 rwhp couldn't be obtained from a motor which is designed to drive on the street with good top end (heads, cam, intake, etc.) and exhaust components. It won't be cheap but nothing is at this power level, regardless of which way you choose to go (nitrous, turbo, charger, etc.).
BTW, I think 600rwhp will be a cake walk when tuning software is available for the ls7 and someone shoves a good sized cam in there with a good set of headers.
#34
I'm shooting for some big big power in my pump gas 434 c5-r headed street/strip motor (actually similar to what you're trying for, not quite as much though cause i'm going through a th400) and my cam is much smaller then most would think on this board. Good luck![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
What would happen if you had to use 93 octane on a 12.5:1 or higher compression engine?
I guess all that can be done is to increase the compression, add the Harrop intake and the ET heads and maybe upgrade the cam......right? Whatever HP it gets, thats about it N/A.
#35
#36
What kind of compression? I have 11.1:1 I believe.
A motor with an efficient intake track like yours or like you are planning is not going to survive wide open encounters on a regular basis with 93 octane. If you are talking about being able to put around on 93 octane with that kind of compression and adding higher octane racing fuel to race or play around that could be done, but you will have to run a cam with a nice late intake valve closing point to do so. What is late you may ask, well that is really up to your cam designer. With the etheads you can get whatever compression you need pretty much so that is an added benefit. If this motor is already built though the pistons valve reliefs may not be in the proper location for the different valve placement of the et heads. I would talk to ET on that one to make sure and this will only be an issue if you have them mill the heads substantially to get your compression up and run a big cam etc. etc. Good luck, I say stay in the road that you are considering, it will defiantely be something a little different and plenty fast.
#37
Will 1 7/8" Grot LT's support 600-650 RWHP N/A
#38
My 454 ci stroker is being built as we speak. I'm using the ET 265's and I'm looking heavily into the Harrop intake. I also am using the Kooks 1 7/8's stepped to 2" w/ 3.5 collector. Since my motor was being built at the same time I bought the heads, I had the ET combustion chamber scanned by Wiesco so they could build the appropriate piston. I don't think you'll have to worry about clearence issues or changing pistons because you gain .150" free drop over a 15* head. You could fit alot of cam in there before you ever came close to the piston. You can also run a much more radical cam with the Harrop intake and still maintain "grocery getter" driveability. Cars in Aussie run 106 LSA's in daily drivers, no problem. If I do get the Harrop intake, which isn't $5k american, more like $3k, I gunna shoot for 650-700 rwhp, N/A. I chose th eN/A route over F/I just because it is so much easier and th epower is always there.
#39
Are you using the 265 41's? Are you going to port them more?
It seems even the ET heads will be the weak link with this Harrop intake feeding it.
#40
What compression are you going with?
