346 vs 408
Old Dec 5, 2005 | 10:54 PM
marine02ss's Avatar
Default 346 vs 408
Why does it seem I see high horespower 346 in the 450- 500rwhp and the same for 408 What gives??
Old Dec 5, 2005 | 10:59 PM
Allergik2dyin's Avatar
It takes a pretty nasty head/cam combo to get 450+rwhp on a 346. You can get around that with a pretty tame head/cam combo on a 408. Add any somewhat radical head/cam packages to a 408 and youll see some pretty impressive numbers.
Old Dec 5, 2005 | 11:10 PM
marine02ss's Avatar
What would be decent cam for a 408 vs a wild 408??
Old Dec 6, 2005 | 09:19 AM
PAGregSS's Avatar
The biggest difference will be area under the curve. While the 408s may peak the around the same area as the 346, it'll make more power throughout the curve and of course, more torque.
I'd say an aggressive came for a 408 would be 260 duration, .620+" lift.
Old Dec 6, 2005 | 01:17 PM
Bryan @ Speed Inc.'s Avatar
tame cams for big inch motors are in the 230-240 range in duration @ .050 lift. wild cams would be 250 and up.
Old Dec 6, 2005 | 03:19 PM
BLKWS6's Avatar
torque is gonna be your main difference in the 2 motors.......no comparing the 2 really...the stroker is def diff animal....
Old Dec 6, 2005 | 03:22 PM
98Z28MASS's Avatar
Yup, your just looking at peak numbers. A heads cam 346 can make 500 rwhp but thats few and far between, and thats with a really big cam (for a 346) and some killer heads and every other bolt-on imaginable. 500 rwhp can be done easily with a 408 and a good sized cam. The curves are gonna be totally diff. too.
Old Dec 6, 2005 | 08:06 PM
SSilverSSurfer's Avatar
ditto
Old Dec 7, 2005 | 04:22 AM
beardWS6's Avatar
I`m going 408 and spraying 200 shot!
Old Dec 7, 2005 | 08:27 AM
LostCauseZ06's Avatar
i have my 408 and im going 300 direct port
Old Dec 7, 2005 | 10:20 AM
98Z28MASS's Avatar
the other thing no one has mentioned that i just thought of is most of the 408's are running lower compression than most 346's as most people end up running some type of power adder (SC, turbo, nitrous). If you were to look at the compression levels on the 346's making 500 rwhp NA im sure the heads were milled to increase compression and hence the hp levels.
Old Dec 7, 2005 | 10:33 AM
777's Avatar
777
A 450RWHP 346ci motor will drive similar to a 525rwhp 408 motor. You have to compare apples to apples. You are talking about like a 232/234 cam and a pretty nice set of heads to get 450rwhp out of stock cubes. That cam in a 408 would drive like a 224/224 in a 346. Don't be confused, a 408 will make a good deal more than a 346 not to mention the large amount of under the curve torque. That's the biggest difference. Drive a 450rwhp 408 and a 450rwhp 346 and tell me what you think, it won't even be near the same driving experience.
