Warm the engine up! and avoid internal problems!!!
. I think it would be a great idea for someone to make a real mice rightup and make it a sticky! people prob look at us with (WTF faces) while we pussyfoot our cars around.
Ive heard a few times tht it isnt good for cars to sit for a long period of time from a cold start. ie- dont park your car and let it reach operating temp from a cold start by waiting for it to warmup. Cars should be under load when they are warming up. even if you are driving slow w/ low rpms
Thanks...
Thanks...
It's not about WHEN you drive it. It's HOW you drive it when it's cold. It could be really cold out, and you can let the car idle for only 30 seconds, but you show the engine less than 2k rpms and very light throttle when you start driving.
The faster your oil warms up, the better it is for your engine and your oil(they will last longer). So it's better not to let it idle cause driving warms it up faster. The temperature here rarely gets below 40º..and it's 60+º most of the time. The only reason i let the oil get up to 80º now is cause i'm paranoid about my new valve springs. but that only takes a couple minutes. If the ambient temperature is like 70+ then just 10 seconds of idling should be fine.
