Replacing one piston and rod?
What do you guys think of just dropping the pan to replace one? I don't even want to take the other head off. Before disassembly the compression was 180-200 psi in all the other cylinders.
It has 113,000 miles, bone stock.
Where could I find just one?
Anyone take the pan off?
My manual says to lift the engine up AND loosen the engine cradle bolts, take the trans pan off. Sounds like a lot but I really just want to get it running as easy as possible.
Belive me if you half *** it it WILL come back and bite you in the ***.
BTW - You can't replace a rod by just pulling the pan because the piston will not come out the bottom and you have to remove it to put the new rod on. You will have to at least pull the intake and one head - after all this it may be almost as easy to remove the motor since working it on a stand is so much easier.
As has been stated, it us unlikely that there no other damage and it would be next to impossible to clean it well enough in the car.
Steve I've rebuilt blown engines before, check out the picture of the one with the hole in it, that was in a 427 big block, metal from that went accross the intake into other clyinders, the rod bent, the cylinder wall cracked. I had it sleeved and built it back up.
The 454 here at the bottom of the page was blown up by someone else.
Yea, this is too much to fix.
Theres also a picture of the LS1 piston (NOTICE HOW IT'S SITTING ON AN LS1 HEAD AND IF YOU LOOK IN THE BACK GROUND YOU MIGHT SEE THE INTAKE).
This all doesn't even matter now, I can't get the title for the car so as it sits right now the engine is ready to pull. Took me 4 hours maybe 5, thought it would be more difficult than it was.
I'm going to pull the rear too.
I may rebuild it and put it in my 2000 S10.
So I'm not going to change just one piston if I do that.
