383 or supercharger???
....so eventually i will have the money to do this...but my question is should i go bore it out and go 383 with rebuilt internals blah blah blah....or should i go supercharger?....now unfortunately my car burns oil and i have a feeling its those shity low compression factory rings in it causing this...not sure but almost positive.....because when i get on it u could see the smoke half mile away....but my car right now has a comp 224/224 112lsa, Ls6intake, slp lid w/K&N,slp smooth below, mac mid lengths, custom y-pipe, random tech exhaust, and 8.5 MSD wires....im starting to get used to the power (lol according to texas boys...lack of power
)....anyway no matter what i do...i plan on yankin the engine either way because i refuse to slap a charger on it with the internals not setup right...and if i decide to stroke then its gonna need a rebuild anyway....i was askin what would be the best rout to take...mainly for the long run...right now im makin about 371hp (untuned)............yea yea dont say it
Good luck.
I've been in your situation before in more ways than one.
Wait until you get to your first duty station before spending any money.
Unless you are married or an officer you'll probably get stuck in a dorm for a while and not have a decent place to work on your project. Base hobby shops charge a lot of fees (go TDY or deploy and they add up fast), and being at the mercy of someone else to work on your car just sucks.
First thing I suggest when you get to your duty station is to look around for a little beater car to buy. In the military getting to work is NOT an option, so you need a reliable back-up plan first.
Then I suggest not building the engine in your car, but build a second engine kept on a stand until ready for the swap. This means less down time, plus a spare engine in case of disaster. You'll be thankful later.
If you're young the best thing you could do is pay off the car early to drop your insurance payment. No need for full coverage on a engine-swap project car.
Once you have your beater car and you want to go fast with your LS1 get a bottle. A $300 dry system will get you the power of a blower and then some for much less money. Meanwhile you have a back-up and can be building engine #2 of your choice.
Who knows, once you run a bottle you may never think about a blower again. Within a year or so you should be able to have engine #2 ready to try.
If you go big cubes, then I suggest buying the shortblock already assembled and with a warranty.
If you buy a blower, make sure it's a match for the cubes you plan to run it on ...same for the heads.
Try running a filter on your PCV line. If the oil was coming from there then it will help.
I don't think you are allowed to drive during basic, but maybe that has changed.
