Ordering new cam and accessories...few ?'s
Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA (however i'll see if I can order the cam on a 112 LSA instead)
As far as the whole package goes...
-Keeping my rockers
-New OEM lifters
-Chromeoly Stock Length Pushrods
-New Timing Chain (which one?)
-Titanium Retainers - really needed?
-Springs, probably Comp 918s unless there is a better suggestion
-Head Gaskets, since the heads need to come off to replace the lifters, so which? I was told TR Coppers is what I should use
-Seals, Locks?
-Cam Gaskets?
Engine has 75k miles. Also saw a QTP Cam Cover and Oil Pump on the TR site...necessary?
Just trying to make sure i'm not overlooking anything...thanks in advance for letting me know what I need & don't need.
-Keeping my rockers
-New OEM lifters
-Seals, Locks?
-Cam Gaskets?
-Keeping my rockers
-New OEM lifters
-Seals, Locks?
-Cam Gaskets?
Although that is a damn good price for the whole kit. I've seen the retainers cost almost that much alone...
And LS2 timing chain is better than the Comp and JWIS, Crane, etc?
But anyway I understand about the dual spring, however I wonder is it harder on the lifters? Will the valvetrain be noisier?
-Keeping my rockers
-New OEM lifters
-Seals, Locks?
-Cam Gaskets?
The patriot dual spring setup is a great deal and insurance. We use them alomst all the time. Net to mention they come with everything. Spring,tit retainers,seals,locks,seats.
As for gaskets..if your carful taking it apart you can reuse all the gaskets if your on a tight budget...if not it dosent hurt to replace them.
Head gaskets...the GM MLS work great for a decent price.
Timing chain cover is not neccessary unless you plan on changing your cam every summer. As for the chain the stock ls2 is great or a hardened rollmaster. I would put a ls6 pump on for some good thought too.
Just my 02
no excessive wear on the cam when you pull it i would leave the stockers on a street car. And i would opt for 'DUAL' springs for the reasons given. Dual R.E.V.s here and T.I.
retainers and i can spin up just don't want to.
Hawk
I guess I could check out the lifters before putting in a new set but wouldn't they have to still be pulled? May as well then after going through all the trouble...
