need some cam recommendations....
Old Dec 18, 2005 | 06:13 PM
1969x11's Avatar
Default need some cam recommendations for stock head m6
im running a 99 ls1 m6 with a 4.11 rear in my 69 camaro.its a show car but i drive the hell out of it,anyway im currently running a tr224 on 114.im going to pull the front clip to build some headers this winter so itll be a good time to change cams.the 224 just doesnt hit enough lick for me.i wnt a cam thats gonna perform well but most of all sound good.im also going to install an ls6 intake. any help willbe greatly appreciated.
Old Dec 18, 2005 | 06:18 PM
1969x11's Avatar
anyone
Old Dec 18, 2005 | 06:36 PM
1969x11's Avatar
search wouldnt work.
Old Dec 18, 2005 | 06:44 PM
Ed Curtis's Avatar
Question
Search is down from what I've heard...
How about more info??
Ed
Old Dec 18, 2005 | 07:31 PM
1969x11's Avatar
car has stock 99 heads, for now stock intake.looking for an ls6intake. going to modify a set of mac mids to fit the car.it has dual 2.5'' exhaust with an h pipe.9''rear with 4.11 gears six speed with a spec stage3 clutch. want a cam that has a serious lope.
Old Dec 18, 2005 | 07:48 PM
Rudolph's Avatar
I would pick the RJ-111 (236/239 .600/.611 111LSA ) from Futral. Those cams have shown pretty good numbers, and with 111 LSA i think that you will have a rough idle as you were requesting With that set of gears you will not have any problem by getting quicker on the power range, besides 111 LSA will also help you
Old Dec 18, 2005 | 09:14 PM
1969x11's Avatar
thanks for the info on the cam. any more opinions on my setup?
Old Dec 18, 2005 | 09:15 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
LG G5X3 or G5X2
Either way, upgrade to a good dual spring like a Comp 921 or Patriot Gold.
Pick a cam in the 230+ duration range with .595-.610 lift and put it on a 110-113lsa and the thing is going to pull/lope/ put a smile on your face.
Old Dec 18, 2005 | 09:42 PM
mykdiver's Avatar
I would get better heads if the power is not what you want. You will gain alot that way, then you will really see the gains from that cam.
Old Dec 18, 2005 | 10:05 PM
!LS1 11 Second Club
Yeah, but it won't lope.
Old Dec 19, 2005 | 02:30 AM
Nittany_marine's Avatar
G5X3.....I love mine, and so do a lot of other users.
Old Dec 19, 2005 | 06:59 AM
1969x11's Avatar
thanks guys so it loks like a g5x3,or a g5x2. with a good set of springs.cant wait to hear it ,gettin stiff already.just kidding
Old Dec 19, 2005 | 08:32 AM
BLK UUS-6's Avatar
I would recommend talking to EDC more. He can set you up with exactly what you want for YOUR car and what your intentions for the car are. His cams make great power.
Old Dec 19, 2005 | 08:33 AM
!LS1 11 Second Club
G5X2 clears fine PTV.
Inquire about the G5X3.
Old Dec 19, 2005 | 09:02 AM
mykdiver's Avatar
What are you more concerned about, lope, or power?
Old Dec 19, 2005 | 09:05 AM
!LS1 11 Second Club
Both.
Old Dec 19, 2005 | 11:08 AM
99blancoSS's Avatar
Sounds like he just cares about lope and not so much power. Regardless of what cam you choose you need to do the supporting mods to get the most out of it. Headers and an intake w/ported tb, crank pulley and a lid. I have the tr224, my numbers are in my sig. Your running a stock cubed 99 ls1? How heavy is your car? the 112 lsa would have been a better choice but if all you want is lope then you have a variety of choices. Headers w/dual exaust will make it sound lopier as well.
Old Dec 19, 2005 | 03:22 PM
1969x11's Avatar
stock cube ,stock head 99 ls1 car is probably weighs about 3300lbs.lope is #1 concern and power is second,thanks again for the help guys btw. not going to race the car but dont wont to get outran by a mustang or a stock ls1.
Old Dec 19, 2005 | 03:32 PM
Ed Curtis's Avatar
Something with 8*-10* overlap and mild lobes to help keep valvetrain alive. Figure a ~228* and ~232* on a 110*... Not a problem...
Ed
Old Dec 19, 2005 | 03:36 PM
!LS1 11 Second Club
Does this mean you're running stock manifolds? That's one of the reasons why the 224 ain't doin' it for ya powerwise.
If you're going to build a header, is it going to be short/mid/long?
Makes a huge difference for your cam selection.
