New 243 Patriot CNC Ported Heads
Old 12-24-2005, 07:49 PM
  #41
1999 SS's Avatar
UOTE=PREDATOR-Z]LS6 "style" are 6.0 heads with welded chambers (64cc/59cc)
243 casting are new GM LS2 castings (05+)
The difference is that welded 6.0 59 cc still keep more PTV clearance to allow bigger cams than if you milled the 243 to achieve 59cc.
I doubt seriously there is a major power difference all components and chamber size being the same, but milled 243's might flow a little less.
In any case, this is a really good deal with Ferrea/dual spring setup.[/QUOTE]
what do you think would be a better head for me(patriot 243 or the ls-6). im running an f14,LT's,90mm fast intake & tb, with all the bolt ons and oem ported 99 heads.
Old 12-25-2005, 02:39 AM
  #42
PREDATOR-Z's Avatar
If I was to do it, I would rather choose the 6.0/ 59 cc heads but with Ferrea valves (2.05/1.57)for a ~11.35 SCR
Old 12-25-2005, 03:26 AM
  #43
Shinsetsu's Avatar
PTV has little to do with lifts and has to do with duration amount used, valve events and size of valves.
The MS3 will fit PP 243 with stock valves and no mill.
It might even fit PP 59 cc with 2.02/ 1.57 valves ( not sure though)
But with bigger valves, the way to do this is stick the cam in and measure PTV.
No sane sponsor here will give you a definite answer, it will be it "should" but "better measure", which is sound advice when you're playing with cams that size.
Would the MS3 and the 243 heads be a good combo? About how much HP would you get with this set up? I want low 11s on motor, and I al searching right now for some answers but I might as well ask.
Old 12-25-2005, 05:11 AM
  #44
PREDATOR-Z's Avatar
If you do not want to flycut, then yes the stock valved/spring 243's unmilled would be a good combo. 400 with proper tuning and supporting mods should be a piece of cake. (Let me put this way, if you do not make 400 with this HC combo, something is seriously wrong.)
Old 12-26-2005, 03:08 AM
  #45
konryod215's Avatar
TSP made 400 with Ls6 intake headers, ture duals, pulley, MS3 cam, and a tune. I'm myself am doing this setup and the 243 Heads with stock valves and hoping for like 440 rwhp
Old 12-26-2005, 04:23 AM
  #46
Jpr5690's Avatar
ok, is any patroit head gonna get me 440-450 rwhp with a cam ms3 or smaller?
Old 12-26-2005, 04:24 AM
  #47
Jpr5690's Avatar
also are there options for larger valves? say 2.055 intake?
Old 12-26-2005, 04:25 AM
  #48
Jpr5690's Avatar
o yea... how do these compare to prc 5.3l stage 2.5r heads????
Old 12-26-2005, 04:46 AM
  #49
PREDATOR-Z's Avatar
100" 75.3 / 61.9
.200" 151.7 / 121.6
.300" 210.7 / 163.1
.400" 251.2 / 199.7
.500" 284.6 / 215.8
.550" 291.4 / 221.1
.600" 301.3 / 225.6
Above is 243 PP with 2.00/1.55 stock valves (advertised by PP)
Below is independent PRC test:
Here are the flow #s:
* SF1020 bench
* 3.900" bore
* Radiused entry on intake side
* Exhaust port flowed open
Intake Exhaust
.050 36.1 30.0
.100 70.0 57.2
.150 103.9 83.6
.200 139.1 110.4
.250 168.3 130.0
.300 198.0 150.1
.350 222.9 165.3
.400 244.4 177.3
.450 262.1 194.1
.500 276.7 202.2
.550 288.4 208.5
.600 298.8 213.3
.650 304.7 216.9
.700 278.4 220.1
Old 12-27-2005, 09:25 AM
  #50
Gunnar@Patriot's Avatar
Anyone that has questions as far as increasing valve size, etc. on these 243 heads, please give us a call or send us a PM.
Old 12-27-2005, 11:58 PM
  #51
Jpr5690's Avatar
ok how much for 6.0L heads milled for 59 cc chambers with Ferrea valves (2.05/1.57) and Patriot Gold .650" Dual Springs, Ti Retainers, Super 7 Locks, Viton Rubber Seals, Machined spring Bases, and Bronze Valve Guides also with these heads could i use an ms3 cam without fly cutting also being im not too smart with this stuff is this all a good setup
Old 12-28-2005, 12:00 AM
  #52
Jpr5690's Avatar
hey im guessing PN:
2017Assy 2.055"/1.57"/72cc$1,195.00 pair
is what im looking for just milled down to a 59 cc chamber
Old 12-28-2005, 12:12 AM
  #53
Jpr5690's Avatar
ok last dumb question... if i can get the above listed heads for $1195 why would i want to pay $200 more for 243 ls6 heads? espically i can use a larger cam with the 6.0L heads..... ??
Old 12-28-2005, 12:18 AM
  #54
PREDATOR-Z's Avatar
You can get the 6.0 with 64cc or 59 cc chambers. No milling necessary.
Old 12-28-2005, 01:03 AM
  #55
Jpr5690's Avatar
but why pay more for the 243's if the 6.0l are better?
Old 12-28-2005, 01:05 AM
  #56
Jpr5690's Avatar
also would a 59cc 6.0l head with 2.05/1.57 vavles perform good with a cam like the ms3? and will this fit ptv problems
Old 12-28-2005, 01:24 AM
  #57
PREDATOR-Z's Avatar
PTV always needs to be measured, and yes 2.05/1.57 is the way to go on stock cubes.
Contact TSP for fitment, since they used to sell PP and would hhave a pretty good idea as to what VE's or if any flycutting is necessary.
Old 12-28-2005, 01:51 AM
  #58
Jpr5690's Avatar
ok so the heads are good regardless or cam choice? and talk with the cam vendor as to what cams will not cause provide ptv problems..?
  #59
Jpr5690's Avatar
also why pay more for the 243's if the 6.0l are better?
Old 12-28-2005, 02:55 AM
  #60
Jpr5690's Avatar
ok ive been searching does it have to do with the welding of the chambers ???
Quick Reply: New 243 Patriot CNC Ported Heads
